Author Topic: cl360 timing chain replacement  (Read 2547 times)
jtoff7273
« on: January 14, 2006, 02:17:04 PM »
Hi,
    I have a acquired a cl360 for $50 in fairly decent shape for a bike that appears to have sat for years. I have pulled the motor and found that the timing chain has a serious kink in it. Does anyone know if there is a way to replace the chain without splitting the case?
thanks,
john in KY
Offline Jonesy
  • Shop Rat
Re: cl360 timing chain replacement
« Reply #1 on: January 14, 2006, 03:39:29 PM »
I'm afraid not. In the shop manual, Honda specifically instructs mechanics not to cut the old chain to remove it nor rivet a new one together. Sorry to be the bearer of bad news.... :(
What year is it? There was a cam chain tensioner update after the '74 model year. I know it applied to the CB360T... Not sure if it includes the CL as well.
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #2 on: January 14, 2006, 08:49:34 PM »
there was a serious problem with the cam chain tensioners on these bikes, and the result is that a great number of them ended up with the cam chain wearing straight through the case. in my opinion, they went downhill from the cb/cl 350 when they made the 360 model. while you're in there, make sure to change that tensioner.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
« Reply #3 on: January 15, 2006, 03:38:35 AM »
Whist Honda said dont do it, i did a few and never had a problem BUT as you probably have the top end off anyway and gasket sets for that are always full sets now considering the time its been stood a full strip and clean out is probably called for and not much more time
jtoff7273
« Reply #4 on: January 16, 2006, 10:33:09 AM »
thanks for the help guys. I think it makes sense just to take another day or so, split the case, and give the bottom end a good once over. I'll also inspect that chain tensioner. Does anyone know if that part is still available?
Offline Jonesy
  • Shop Rat
« Reply #5 on: January 16, 2006, 02:35:45 PM »
CMS has all the parts you need for the cam chain tensioner retrofit. I am going through this on my CB360T.
Send a Private Message to Bill Vaughn. He has a PDF copy of the tensioner refit manual and the part numbers.
« Last Edit: January 16, 2006, 02:38:58 PM by Jonesy »
Offline Bill Vaughan
« Reply #6 on: January 17, 2006, 08:15:43 PM »
Part numbers for the updated parts appear below:
Slipper/Tensioner - 14520-369-010
Holder - 14530-369-020
Damper A - 14565-369-010
Damper B - 14567-369-000 (this is the original style part, but worth replacing while you're in there.
I attempted to attach the factory manual supplement that details the update, but the file is too large for this site now.  If you need it, send me a private message with your email address and I'll forward it to you.
1972 Z50A
1973 ST90
1975 CL360
1971 CB450
1975 CB550
1978 FLH
2003 FLSTS
2006 FLHRSI
