Author Topic: Hole in exhaust - bad?  (Read 3085 times)
Justin_NJ
« on: April 24, 2005, 06:40:39 PM »
I've got a hole in my CB550 #4 exhaust caused by rust.  It makes popping noises and I can feel some of the exhaust pressure flowing out of it.  Will this cause any problems?  And will I be able to pass inspection like this?
Thanks,
Justin
« Last Edit: April 24, 2005, 07:06:31 PM by Justin_NJ »
Offline Bob Wessner
  • "Carbs Suck!"
Re: Hole in exhaust - bad?
« Reply #1 on: April 24, 2005, 07:07:45 PM »
You could go to an auto parts store and get some muffler tape as a temp fix.
Offline Dennis
« Reply #2 on: April 24, 2005, 07:55:42 PM »
Or go to Home Depot or some other home center or heating supply house and get that aluminum tape that they are using on ductwork now. Very shiny stuff. Should almost blend in with the chrome. It's a temporary solution anyway!
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #3 on: April 25, 2005, 01:22:46 AM »
Blowing exhaust is a failure on Inspection in UK (we call it "MOT" after the government department that introduced it). Can't think your rules will be very different.
« Last Edit: April 25, 2005, 02:14:33 AM by SteveD CB500F »
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline heffay
« Reply #4 on: April 25, 2005, 01:27:10 AM »
Justin_NJ
« Reply #5 on: April 25, 2005, 10:42:29 AM »
Is there a way to patch the holes or can I get something less than a completely new exhaust system?
Justin
Offline cb650
« Reply #6 on: April 25, 2005, 01:45:01 PM »
A good welder should be able to fill that in.  Or mr jb weld?
                               Terry
Offline keiths
« Reply #7 on: April 25, 2005, 02:43:09 PM »
I used a product called 4 minute epoxy steel type 44 by VersaChem. It is used to seal and fill holes in engine blocks and steam pipes. It dries to a dull gray. It can be sanded but I didn't bother. I used chrome bumper paint to finish it off. My temporary fix has held up well for 2 years, but I don't have that many miles on it.
