Author Topic: For all the GEAR RATIO enthusiasts  (Read 1650 times)
Offline 750goes
  • it will live
« on: January 15, 2006, 12:58:06 AM »
Found this simple program, you decide if you want to download it... it looks worthwhile for the people who don't want to use their calculator,
or wouldn't know how to like me....
http://home.austin.rr.com/ironjungle/programs/gc_v3012.zip
Offline 750goes
  • it will live
Re: For all the GEAR RATIO enthusiasts
« Reply #1 on: January 15, 2006, 01:01:07 AM »
I'll throw in a bit of text, to show what it does........sorry should have done that first
GearCalc README File.
DISCLAIMER:  User accepts program as is.  Author assumes no risk.
Requires Windows 3.x, Windows NT, or Windows 95.
Ever wonder...
   - The bike's RPM at 60MPH?
   - The bike's engine RPM when cruising down the highway?
   - How will adding a tooth to the rear sprocket effect the top end?
   - What gear ratios are right for the new track?
   - The bike's top end at redline?
   - Is putting on a taller tire a good idea?
   - etc., etc., etc....
      ....wonder no more!
   Welcome to GearCalc!
Installation is pretty easy.
   - Copy GC_Vxxx.ZIP to the folder or directory of your choice.
     (where "xxx" is the revision number of your GearCalc program.)
   - UnZip the file GC_Vxxx.ZIP (goto www.winzip.com is you do not know how to UnZip a file).
   - Double click on GEARCALC.EXE from File Manager or Windows Explorer to run the program. This will run GearCalc.
   - You can delete the GC_Vxxx.ZIP file.  It is no longer needed.
Installation Note:  The program require the MicroSoft file "VBRUN300.DLL" to be on your PC.
              The "VBRUN300.DLL" can be in your "Windows System Directory" or it can be in the
              same directory that you copied your new software to.
              You probably don't even need to worry about this because almost every computer
              we already has the file "VBRUN300.DLL" on the hard disk from the factory.
      If you do not have "VBRUN300.DLL" you can download it from Microsoft.
      There is also a copy of "VBRUN300.DLL" on the www.ironjungle.com "IJ Software" page.
NOTE:  GearCalc v3.xx+ will NOT read GearCalc v2.xx files.
I hope you find the program useful.
   Registration will remove the 'Welcome' screen and enable the File Save feature.
   Visit us at:  http://www.IronJungle.Com
      for details on how to register.
Developed at:
   The Iron Jungle
   "all rights reserved"
Offline dusterdude
« Reply #2 on: January 16, 2006, 03:32:04 PM »
i need to download this damn vbrun thing,when i try to load it,it asks what program i want to open it with,any ideas?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
« Reply #3 on: January 16, 2006, 04:03:08 PM »
If I remember right it needs to be copied to your system or sytem32 folder.  C:/windows/
Been awhile since I had to install it.
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
Offline Bodi
« Reply #4 on: January 16, 2006, 09:34:57 PM »
The vbrun300.dll is the visual basic runtime component (dynamic link library to be accurate), it just has to be present to use programs created with "visual basic" (a microsoft program that makes creating simple windows programs pretty easy). You can't run the .dll file, so Windows will ask you what to do with it if you try.
Most systems will have this already so try running the actual GearCalc program and if it won't go, try putting the .dll where the readme suggests...
Offline dusterdude
« Reply #5 on: January 17, 2006, 10:19:41 AM »
when i tried to download it off the website,i get a window that says open or save,i press open.then i get another window that asks which program i want to open it with.something aint jiving with this deal.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #6 on: January 17, 2006, 10:24:35 AM »
DD,
Should have selected 'save' to the location he indicated or then copy it to the he location indicated. Give it another try. It's also a compressed file so you will have to unzip it and direct the unzipped file(s) to the correct Win folder.
« Last Edit: January 17, 2006, 10:35:59 AM by Bob Wessner »
Offline dusterdude
« Reply #7 on: January 17, 2006, 06:22:37 PM »
bob,you is the man.i loaded the vbrunthing into the gearcalc folder and it opened right up.thanks
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
