Author Topic: Cable from Tach to Engine  (Read 1072 times)
Offline dgilling
« on: March 06, 2010, 12:00:59 AM »
On my 1977 CB 750 the cable from the Tach to my Engine has a hole in it and leaks oil where it connects to the engine.  Is there oil in it?
Offline City Boy
Re: Cable from Tach to Engine
« Reply #1 on: March 06, 2010, 03:28:30 AM »
Hi.There may be a small amount of oil or grease in cable housing for lubrication.A continueing leak is likely from a leaking seal at tach drive housing behind cable.    Rock On
'52 Kiekhaefer Mercury Rocket Hurricane KG4H
'70 750/RC 1000 Original Owner
'83 1100F
Offline markb
  • When I finish my current project I might be a
« Reply #2 on: March 06, 2010, 04:12:41 AM »
Yes, if the seal in the valve cover is bad you can get engine oil in the cable but you should also see oil around the cable end where it goes into the valve cover.
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline Johnie
« Reply #3 on: March 06, 2010, 06:04:11 AM »
You can still get that seal from Honda and it is pretty inexpensive. There is info in the FAQ about removing the old seal and installing the new one. Not a bad job at all.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
