Author Topic: $3.29 Wheel Bearing Driver  (Read 8039 times)
Offline JBMorse
    • Travel Blog
« on: March 08, 2010, 07:19:17 AM »
My favorite thing about hardware stores is that people rarely use the various bits of hardware for their intended purposes!  This weekend I was in need of something to bang in my new wheel bearings for the rear wheel on my CB500.  I didn't have any sockets big enough, couldn't find any scrap lumps of pipe or other appropriate metal things.  So I broke down and made a trip to the hardware store.
I planned on buying a short length of iron pipe, but then discovered a coupling that fit just right.
It's a 1.25"X1.5" iron pipe reducer.  It just happens to fit the outside races of the 6304 and 6305 bearings.
Best of all, it was only $3.29! (US Dollars!)  So hopefully I saved some people some dollars and/or frustrations!
Cheers
Jeremy B
1971 CB500K
Offline mystic_1
  • 1970 CB750K
Re: $3.29 Wheel Bearing Driver
« Reply #1 on: March 08, 2010, 10:15:37 AM »
Not too shabby!
Hmm, you could probably get some more adapters/reducers, plus a short threaded nipple, and make a whole bearing driver set for all the bearings on the bike.
mystic_1
- John Augustus Shedd
Offline Johnie
« Reply #2 on: March 08, 2010, 10:33:48 AM »
I just lay the old bearing over the new bearing and tap it in. But you have a nice idea there.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline JBMorse
    • Travel Blog
« Reply #3 on: March 08, 2010, 11:14:31 AM »
I had considered using the old bearings to drive the new ones in, but I thought that tapping on the inside races could damage the new bearings.  And I didn't see any way of dismantling the old bearings to separate the races.
Did you just concentrate your tapping on the outside races of the old bearings, or somehow get them apart?
1971 CB500K
« Reply #4 on: March 08, 2010, 11:29:32 AM »
Yeah I blindly followed the tradition of using the old ones over. and tapping around the outside. Almost always good for smacking a finger once in a while.
I'd prefer something bigger to hold onto.
Offline Johnie
« Reply #5 on: March 08, 2010, 12:47:31 PM »
Correct, I just concentrated the tapping on the outside races of the old bearings. Been doing that with car and bike bearings since the 70's. Not to say there may be better ways to do it, I just stay with what worked for me.
Oshkosh, WI  USA
Offline Laminar
  • Retsam
« Reply #6 on: March 08, 2010, 12:51:15 PM »
I used a 27mm socket and 4" extension.
Offline Johnie
« Reply #7 on: March 08, 2010, 01:50:20 PM »
You just have to be careful with what size thing you pound on in that rear hub or you could bugger up the retainer ring threads.
Oshkosh, WI  USA
Offline wildcatmahone
  • Poseur
« Reply #8 on: February 22, 2011, 06:37:10 PM »
Good job! Easy with the hammer honestly the plumbing section of Home Depot has saved my ass many times...
« Reply #9 on: September 03, 2013, 06:05:46 PM »
I Like using PVC unions and the like.
Offline CycleRanger
  • No comment about being an
« Reply #10 on: September 03, 2013, 08:43:51 PM »
Yeah, PVC is both cheaper and safer.  It's hard enough to drive the bearing but softer than the metal.
