Author Topic: carb help  (Read 1007 times)
Offline Ivanitsky45
carb help
« on: March 09, 2010, 09:22:40 AM »
I have a 75 CB400F that I am trying to clean up starting with the carbs. While trying to unscrew the phillips head screws that are in the slide/link arm area that allow access to the needle, I stripped one phillips head.
Has anyone ever done this and if so, what is the best way to go about drilling the stripped screw head out so I can change the needle?
Offline domer
Re: carb help
« Reply #1 on: March 09, 2010, 09:30:06 AM »
get a dremel and a cut off wheel, cut a nice slice in the top of the screw... keep in mind if you cut too deep the head might split, to shallow and it might strip again! grab a flathead and go nuts.... oh and replace them all with s/s allen head socket screws...
Offline westondc
  • Wes Mantooth
Re: carb help
« Reply #2 on: March 09, 2010, 10:10:08 AM »
is the space and head of the screw big enough to grab with a small vice grip pliers? grab tight and twist it loose, worked for the stripped srews and bolts on my bike.
B.O.X.N.I.F.E. Hospital fund https://www.everribbon.com/ribbon/view/8352
Rider no. 115 on the 2012 SOHC/4 Honda World Tour
Rider no. 274 on the 2011 SOHC/4 Honda World Tour
1972 Honda CB500k1
1971 Honda CB350k3
the project http://forums.sohc4.net/index.php?topic=64499.0
Trip/Project Blog http://easterntowestern.blogspot.com/
just be a vagabond, living out of a backpack on a little Honda, cruisin all over the damn place....
"As your attorney, I advise you to buy a motorcycle. How else can we cover a thing like this righteously?"
Offline cb750fbomb
  • is by no means a
  • "No hope? See, that's what gives me guts!"
Re: carb help
« Reply #3 on: March 10, 2010, 07:27:51 PM »
That's worked for me more than once as well.
'77 CB750F2
“The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair.”
wdhewson
Re: carb help
« Reply #4 on: March 10, 2010, 08:11:30 PM »
I think that Ivanitsky45 might be working with one of the two very small Phillips screws down inside the tubular carb slide.
If this is the case, you do indeed have a delicate surgery ahead.  An impact driver is a wonderful tool but you need to find some rare mini attachments for that small screw, and support the screw from below so the impact blow doesn't wreck the slide.
You could drill the Phillips head off, and your drill may eat into the plate below the screw, but delicate execution will minimize this.
I just did two racks of CB350F carbs and all the small Phillips screws were very tight, and their fastening probably goes right back to day one in Japan.  Good luck.  Don
