Author Topic: HOW DO YOU REMOVE MAIN JETS ON A K2?  (Read 762 times)
Offline jcarthel
  • K2 Justin
« on: March 09, 2010, 10:32:27 PM »
MY 1972 CB 750 STILL HAS ITS ORIGINAL CARBS IT WAS BORN WITH.  ARE THE MAIN JETS SCREWED OR PRESSED IN?  HOW DO YOU REMOVE THE MAIN JETS?  I KNOW YOU REMOVE THE IDLE JETS BY UNSCREWING THEM WITH A SCREWDRIVER.
JUSTIN
Offline nancy
  • CB750 K2'ish - SOLD!! Triumph Sprint GT2011
  • No worries matey..
Re: HOW DO YOU REMOVE MAIN JETS ON A K2?
« Reply #1 on: March 09, 2010, 10:44:19 PM »
Slow and main Jets are screw/nut fit - remove with small socket. Remove float bowl cover. Jets visible - also have slot for flat-blade screwdriver. Advise using socket. Both are positioned between the floats.
Offline kghost
« Reply #2 on: March 09, 2010, 10:50:39 PM »
A six point socket to be real specific.
8mm if memory serves
Stranger in a strange land
« Reply #3 on: March 10, 2010, 03:44:24 PM »
Don't crank the emulsifier tube / main jet down to hard when putting back in carb body for fear of cracking the alloy housing.  ;)
