Author Topic: Are these cam towers worn out?  (Read 885 times)
Offline MattFreeman
  • What Have I Done?
« on: March 12, 2010, 01:49:52 PM »
Hi guys.
The project get's bigger every time I clean apart. Can anyone with an experienced eye tell me if I need to replace my cam holders?
Offline bucky katt
  • i am a pastafarian!
    • facebook
Re: Are these cam towers worn out?
« Reply #1 on: March 12, 2010, 03:32:08 PM »
if you have a telescoping bore gauge set (borrow one if not) and check the size of the bore at at least 3 positions then with the same micrometer you measured the bore gauge with, measure the cam bearing journals.
Mark Twain - Notebook, 1894
Offline City Boy
« Reply #2 on: March 12, 2010, 06:01:30 PM »
Hi Matt.I have seen and used worse without failure.If the scuffed area I see in your picture is slight,I would suggest plastigage the 4 bearings and if you have less than 0.0083'' or 0.21mm [from oem manual],I think you would be good to go.If cost or availability is not an issue,new  may let you sleep better .   Rock On
'52 Kiekhaefer Mercury Rocket Hurricane KG4H
'70 750/RC 1000 Original Owner
'83 1100F
Offline MattFreeman
  • What Have I Done?
« Reply #3 on: March 12, 2010, 07:47:51 PM »
Thanks for the input there fellers. I had a pair of clean ones fall in my lap tonight.  :) :) :)
Offline bucky katt
    • facebook
« Reply #4 on: March 12, 2010, 07:50:58 PM »
hang onto the others in case of emergency. i never throw parts out unless theyre obviously not usable even a little bit, like the shelf full of pistons from my race bug's cylinder #3
Offline wrenchmuch
« Reply #5 on: March 12, 2010, 07:58:15 PM »
Cam towers from heaven . Nice . Read what Hondaman has to say about rocker arm shafts in the FAQ section under Thoughts of Hondaman if you haven't already . That whole section is a great read .
CB750K1
CB750K4
Offline bucky katt
    • facebook
« Reply #6 on: March 12, 2010, 08:03:22 PM »
when i rebuilt my motor i used a bunch of hondaman tricks on the k4 750
Offline MattFreeman
  • What Have I Done?
« Reply #7 on: March 13, 2010, 11:07:03 PM »
I was very fortunate.
Definitely looking to the Hondaman thread for advice.
Here's to running by spring. :) :)
