Author Topic: How long would you let this go?  (Read 1486 times)
Offline brett_bike
  • '73 CB500 Four K2
« on: March 12, 2010, 05:27:21 PM »
Recent oil leak.  Thanks to all the helpful info from the members of this forum I've done carb rebuild, clutch plates, tapered headset bearings, fork rebuild, full tune up, etc.  However I am a little intimidated to take on this oil leak.  Should I do this soon?  Any advice would be appreciated.
Offline bucky katt
  • i am a pastafarian!
    • facebook
Re: How long would you let this go?
« Reply #1 on: March 12, 2010, 05:30:31 PM »
not sure on the 550 but i imagine the source is the same as on a 750. there are rubber "pucks" under the cam holders and those start to leak. as long as it isnt really dripping out badly i'd leave it alone until rebuild time if you can.
Mark Twain - Notebook, 1894
Offline kghost
« Reply #2 on: March 12, 2010, 05:31:39 PM »
Depends how much it leaks.
If its just a seep I'd ride it
Stranger in a strange land
Offline bistromath
« Reply #3 on: March 12, 2010, 06:07:40 PM »
Ride it until you get sick of cleaning the oil out of your jeans.
'75 CB550F
Offline Gordon
  • 750K1, 550K2
« Reply #4 on: March 12, 2010, 06:16:18 PM »
Cut some lengths of cotton rope to fit.  Wedge a piece in the fins where it's leaking.  After a while when it's saturated pull it out and replace with another one.  Repeat until rebuild time! :)
Offline vance
« Reply #5 on: March 12, 2010, 06:46:20 PM »
I had the same leak on my '77 cb550. On each end of the engine there is an o-ring sandwiched between the cylinder and the cylinder head that seals an oil passage. That is probably the source of your leak. It's nothing to worry about so you can let it go indefinitely but it is annoying if you like to keep your engine clean. Unfortunately if you pull the cylinder head off to replace those o-rings you'll have to replace the head gasket as well.
I rolled up paper towels and stuffed them in between the fins on rides and that worked pretty well for soaking it up.
1977 cb550k "Old Gray Baby"
Offline famoussas1
« Reply #6 on: March 12, 2010, 06:53:37 PM »
haha..i love it. my jeans are oily when i ride for a while...i got the same problem. and i didnt fix it this season, but prob. will next winter. i have a 74 550. maybe ill try the rope trick.
Offline Gordon
  • 750K1, 550K2
« Reply #7 on: March 12, 2010, 07:14:46 PM »
You should, it works great!  It's also good for a leaking tach cable oil seal while you're waiting for the new one to arrive or waiting until you need more parts to place an order.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #8 on: March 12, 2010, 07:19:19 PM »
+1 on the rope trick.  No reason to tear into an otherwise solid engine.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline MickeyX
« Reply #9 on: March 12, 2010, 07:23:06 PM »
Don't blame this one on me... I read it on this site somewhere... someone used tampons (new I assume ::)) to soak it up until they could fix it.
Yes, it was a man.  ;D
Offline edbikerii
    • Gallery
« Reply #10 on: March 12, 2010, 07:26:01 PM »
Problem is, those o-rings only last another maybe 10,000 or 15,000 miles even after you replace them.
I've heard talk of people using better quality o-rings that don't decay as rapidly as the OEM o-rings.  Perhaps they were viton?
I have a theory that this may be related to hotter running temperatures on the 77 and 78 models due to the "lean-burn" carburetors.  I went to great lengths to re-jet my bike so that it ran as cool as possible (much cooler than stock).  I don't yet know the long-term effects of the cooler running on those o-rings.  See the jetting link in my sig for cooler running info.
If you have had this o-ring problem, can you please post your year and perhaps any pertinent jetting information?  Pods or airbox?  stock exhaust or 4->1?  Did the o-ring failure follow soon after any jetting-related changes such as adding an aftermarket pipe or muffler?
I'll start:
* 1977 CB550K  bought with 13126 mi.
   PD46C carbs
   stock jetting
   o-rings NOT LEAKING YET
   RIDDEN IN EXTREME CONDITIONS, 100F+ in summer in nasty city stop-and-go traffic, and as cold as 6F in winter.
* 15,825 mi. had stock mufflers with one rotted through at about 16,000 miles, replaced with MAC 4-1.
* Started leaking oil around 20,000 mi.
* 23,358 mi. replaced paper air filter with UNI foam filter in airbox.
* 24,515 mi. oil leak became unbearable any longer, so I replaced head gasket with Vesrah set. (1997)
* 26,453 mi. Installed EMGO pods.
* 26,468 mi. re-jetted to 105 mains, optimized for best "seat of pants" tuning and lowest running temps of 303F at head gasket and 278F at base gasket. (2007)
* I've had no head-gasket o-ring failure since then, but who knows when it will fail again?  Bike doesn't see those extreme conditions any longer, but also doesn't get ridden anywhere near my old daily rain-or-shine commute.  Now she's a "garage queen".
« Last Edit: March 12, 2010, 07:27:51 PM by edbikerii »
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #11 on: March 12, 2010, 08:12:27 PM »
On my K8, I just roll up a couple of tiny balls of paper towel and jam them in between the fins with a screwdriver. You can't even see them!
Wash bike, change them out. Same as post above, just without the rope ;D
I just can't see a top end rebuild for a small issue ;)
Non of my others leak?
Offline mrbreeze
  • Not your average
« Reply #12 on: March 12, 2010, 09:55:17 PM »
At least you can fix it with the engine in the bike.If and when mine starts leaking and gets bad enough to saturate my pants..............Gordon's frame kit will finally get installed!!!!
MEMBER # 257
Online bryanj
« Reply #13 on: March 12, 2010, 11:10:50 PM »
oil mist is OK liquid oil visibly leaking strip and rebuild BUT you need to pull the cylinders and do the base gasket and "O" rings in there as well
Offline brett_bike
  • '73 CB500 Four K2
« Reply #14 on: March 13, 2010, 05:41:50 AM »
So far oil is not misting my pants.  I just hope that if I let it go it will hold out 'till next winter.  I don't want to miss any riding time this summer.
Next winter the engine is coming out anyway for a frame powder coat.
