Author Topic: my 350f won't start at all..........  (Read 1375 times)
Offline jamesb
« on: March 12, 2010, 09:07:41 PM »
all it does is jus cranks over and backfires or pops any ideas on what it could be  thanks
Offline myhondas
  • Not really such a
Re: my 350f won't start at all..........
« Reply #1 on: March 12, 2010, 09:16:45 PM »
Think this belongs in the for sale thread. ;D
I'll bid $20 for the non runner parts bike ya got there ;)
Sounds like timing.....Start with the basics.....Check for spark at the plugs.....check the points/condenser.....make sure your air cleaner is clean.....getting fuel to the cyl's.....then if necessary, check lifters and compression.
I believe you should keep it simple and start with the most basic first.
1974 CB 750 K4 SHOWROOM
1965 C100 CUB 50 (PIT BIKE)
1996 VF 750 CD daily rider
SOHC# 5105 11228
Offline camelman
  • Man... Myth... Legend
« Reply #2 on: March 12, 2010, 09:28:56 PM »
#$%*ty plugs bro.
#$%*ty plugs broski.
#$%*ty plugs brozinski.
Take your pick, then get figure out how to do a basic tuneup.
d-bike (aka Camelman)
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline jamesb
« Reply #3 on: March 12, 2010, 09:33:48 PM »
plugs look good getting spark at all of them points are good i'm going fricking nuts with it i've done went threw it 4 times at least i have all day tomrrow and sunday.
Offline steamnjn23
« Reply #4 on: March 12, 2010, 09:45:40 PM »
same problem when i tried to start mine the first time.  in a fit of frustration i switched the coil wires.  instead of yellow to yellow and blue to blue, i went yellow to blue on both coils and it fired right up.  runs great...now i have to switch the points wires
1976 cb550
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #5 on: March 12, 2010, 09:52:01 PM »
Points are "good"?  So you checked the timing and the gap?  It sounds like your guessing as to what to do.
Do you have a manual?  If so, follow the procedure for setting the timing.  Then check the valve clearance.  If you don't have a manual, get one.  There is a thread here that has links to where you can download a manual.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline Nikkisixx
« Reply #6 on: March 13, 2010, 07:32:35 AM »
Meh, it would be better to have two days to ride!  My advice is to be methodical.  Start at one end of the ignition system and check every connection and component - even if you know it is right.  For example:
1. Pull the plugs and check the gap and condition, verify they are not resistor plugs (D8EA NOT dR8ea)
2. After the plugs are back in, verify plug wire resistance and then firing order
3. Verify wiring at coils ( as steamnjn said)- check the diagrams - measure voltage at coils
4. Verify continuity from coil to points
5. Check point condition - are they flat on the plate, in good shape, gaped right? A little tighter is better than too loose to get it running.
6. Timming good?  Retarded slightly makes a motor easier to start
you get the idea.  I find it is better to go through the system from one end to the other rather than jumping around.  Be as logical and methodical as possible. Once you complete the ignition system, move on to the fuel system gas tank to intake rubbers, and then valve lash.  Good luck, hope you get to take a spin around the block today!
Offline killerdwarf
« Reply #7 on: March 13, 2010, 08:18:46 AM »
How is the fuel system?
Offline jamesb
« Reply #8 on: March 13, 2010, 09:10:34 AM »
ok so i'm going to confess something i had my points wires crossed up under the seat. everything is great on that end of it now it's a carb problem i was curious and  opened the left side bowl screw fuel came out went to the right side did same thing nothing so it's not getting fuel to the right side. my weekend goal is to conquer this blasted machine.what sucks is i just built my chopper in a 2 1/2 week time frame no problems at all couldn't ask for a better build. i've been working on this 350f for about 7-9 months and it wont start.and thanks to all you guys for the help.
Offline myhondas
  • Not really such a
« Reply #9 on: March 13, 2010, 09:59:16 AM »
Oh I am sure it is just God's way of punishing you for building a chopper ;D ;D ;D
SOHC# 5105 11228
Offline jamesb
« Reply #10 on: March 13, 2010, 12:01:12 PM »
i got the carbs off all the float bowls are empty except for the far left. and also i swear i heard a voice in my ear one night whispering "build a chopper"
Offline myhondas
  • Not really such a
« Reply #11 on: March 13, 2010, 12:37:35 PM »
I think it meant the whirly bird kind.... not the 750 kind ;D ;D ;D
So as I said....keep it simple....need all three to make it go.... fuel, air, spark at the same time in a sealed place.....found your problem with same "TIME" in the points, now need to figure why no fuel.....Oh did you check to make sure you petcock was open...don't laugh.... wouldn't be the first time it has happened.
SOHC# 5105 11228
Offline Bodi
« Reply #12 on: March 13, 2010, 01:38:47 PM »
This is odd since the fuel enters the rack in the centre and gets distributed through all four through connector plugs between each pair of carbs: the centre one also has the inlet nipple. So probably you have three float valves stuck closed or plugged with gunk?
Offline jamesb
« Reply #13 on: March 13, 2010, 01:43:26 PM »
beleive me the petcock was the first thing i checked plus 50 more times after that.well it started after taking apart the carbs and cleaning them out again.now it just wont stay running i have to keep giving it throttle.so i'm gonna go through the timing again and make sure it's straight.
Offline steamnjn23
« Reply #14 on: March 13, 2010, 09:01:28 PM »
did you bench sync 'em?
1976 cb550
