Author Topic: 350f is running good but.............  (Read 906 times)
Offline jamesb
« on: March 14, 2010, 07:30:22 PM »
so i got my 350f running good the only problem now is when i put it into first gear and try to go it dies.bike runs excellent in neutral but as soon as i put into gear and try to go it dies. is tis just a clutch adjustment problem if so does it need tightend or loosend thanks again for any help.
Offline hoodellyhoo
  • CB350F
Re: 350f is running good but.............
« Reply #1 on: March 14, 2010, 07:59:03 PM »
Are you putting it into gear while on the center stand? Either way it sounds like either clutch adjustment or stuck clutch plates from sitting.
Offline jamesb
« Reply #2 on: March 14, 2010, 08:24:21 PM »
no it's sitting onthe ground when i put it into gear. if it isn't adjustment and it's clutch plates what is your suggestion on getting them unstuck.
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: March 14, 2010, 08:29:04 PM »
Try putting it in 5th gear and rocking it back and forth
Offline bender01
« Reply #4 on: March 14, 2010, 09:52:25 PM »
Is the Battery good?
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline fmctm1sw
« Reply #5 on: March 15, 2010, 06:02:43 PM »
At risk of being flamed, I'll offer that I sprayed mine with berryman b12... :-X
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
