Author Topic: Chrome vs S/Steel Engine Cover Bolts  (Read 1455 times)
Offline mick7504
« on: March 15, 2010, 06:08:23 AM »
I was wondering what the opinions were on these.
There seems to be varying views either way with Stainless or Chrome.
I noted that Ken at Cyclex mentions that he doesn't like his engines looking like the kitchen sink  :D using stainless screws, although he does have chromed screw kits available.
If I was you
I'd be worried about me.
Markcb750
Re: Chrome vs S/Steel Engine Cover Bolts
« Reply #1 on: March 15, 2010, 06:35:09 AM »
I have found the chromed bolts to be a lower quality because the thickness of the chrome impacts the thread & wrench negatively.
Offline Old Scrambler
« Reply #2 on: March 15, 2010, 05:24:59 PM »
+1 with Mark on the poor fit for chrome finishes. I just bought a set of stainless screws with allen heads for a project. On original restorations I use original cap-screws. The stainless heads are noticably larger.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #3 on: March 15, 2010, 05:58:26 PM »
Does anyone know where to get anodized engine cover bolts.? I am after gold anodized bolts for the majority of the engine and black anodized bolts for the tappet cover.
Markcb750
« Reply #4 on: March 15, 2010, 06:04:35 PM »
Anodizing is a process for aluminum, I do not think this type of color can be developed on steel & stainless steel based bolts.
McMaster-Carr used to have some anodized aluminum bolts.
Offline Gorms
  • Barkeep! Give me a beer and a
« Reply #5 on: March 15, 2010, 06:14:26 PM »
Chrome bolts just look too shiney to me.  The SS bolts have a nicer, more natural shine to them and look much better I think.
« Reply #6 on: March 15, 2010, 06:17:45 PM »
Sorry guys, i should have said aluminum bolts, i have seen them on bikes before but haven't been able to source any here..
« Reply #7 on: March 16, 2010, 09:16:10 AM »
Mick.........you could get the originals or any new steel refinished with yellow zinc. They would match the spoke nipples.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Offline wardenerd
  • '77 550F '81 650C
« Reply #8 on: March 16, 2010, 10:42:34 AM »
i put stainless steel on mine to get rid of those black looking screws and MAINLY to make it easy to open the thing up when it eventually breaks down.
Offline ttr400
    • ttr400 Projects and Billet parts.
« Reply #9 on: March 17, 2010, 08:53:04 AM »
Check out pro bolt in the UK, they also have US distributors. All the stainless,aluminium,Ti bolts, nuts etc in a range of colours. They also have Stainless fasteners that are coloured.
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
« Reply #10 on: March 17, 2010, 04:35:07 PM »
Kevin
Thanks Kevin, they have an Aussie distributor as well, and do kits for the 750.... ;)
Offline Gregorymoto
  • SOHC Aficionado
« Reply #11 on: March 17, 2010, 05:37:13 PM »
I did not read all the reply i'm sure this was covered.
stainless is the way to go. They don't rust and if you use a little anti seize on the threads you will never have issue getting them out unless you over torque.
Putting Steel into Alum even if you use anti seize can bite you in the but giving enough time.
Yep, i have issues with this sort of stuff.
« Reply #12 on: March 17, 2010, 05:59:04 PM »
I have used aluminum bolts before on my bikes with no trouble at all....If i recall there is a special lube that you put on the aluminum bolts to hinder electrolysis...
Offline Gregorymoto
  • SOHC Aficionado
« Reply #13 on: March 19, 2010, 07:11:14 AM »
Yep its called anti seize , you should use it on all bolts.
