Author Topic: Just need a little direction,--fuse order--electrical problem 1975 cb550  (Read 2546 times)
Offline L.A. Nomad........
  • 1976 CB550 K
1975 CB 550
When the key is turned on, with the headlight and tail light on. What kind of power should I be getting to the fuse box?
There are 3 fuses left to right 1,2,3. I'm only getting power to fuse #3. Fuses 1 and 2 have no power.
Everything works fine, head lights, tail light and starter motor. I'm just not getting power to the points and plugs. I've cleaned the points with a points file, but there's just no power. I think it might be the kill switch?
Am I suppose to be getting power to fuses 1 and 2 when the key is turned on?
Thanks, L.A. Nomad
I am a fuel-injected suicide machine! I am a rocker! I am a roller! [I’m an outta controller] I am the Chosen One! The Mighty and the Vengeance! Sent down  to strike the unroadworthy! I'm hotter  than a rolling dice!
Re: Just need a little direction,--fuse order--electrical problem 1975 cb550
« Reply #1 on: January 17, 2006, 11:51:30 AM »
Battery potential.
Yes.  What terminals are you measuring accross?
Offline cadler
« Reply #2 on: January 17, 2006, 11:56:40 AM »
Is it possible fuse 2 and 3 are spares? I have a cb750 and they have 2 spare fuses in case you need one in an emergency.
Power and voltage are 2 different things, Power = Volts X Amps
Just trying to help
« Reply #3 on: January 18, 2006, 12:14:46 AM »
1975 CB500? Where are you as that should only exist in UK and have one fuse in a white plastic holder
« Reply #4 on: January 18, 2006, 12:23:35 AM »
I'm thinkin' Bryanj might need computer glasses.   8)
I do. ;D ;D ;D
Even so, sometimes we read what we are looking for.  I have.
« Reply #5 on: January 19, 2006, 08:18:03 AM »
Damn! you is right! I must stop doing keyboard time after a long night at work. Yup the 550 has 3 fuses 1 for "main" 1 for sidelights and 1 for headlight it does make the loom more complicated with more connections to corrode though
  • 1976 CB550 K
« Reply #6 on: January 19, 2006, 10:43:37 AM »
It's 550k and I figured it out. This model has a light switch, unlike my other 76 Cb550. When The light switch is on, all fuses get power. When the switch is off only the main fuse has power.
My points and coil were not getting any power, I figured out the kill switch had an exposed wire. So out comes the black electrical tape!
Thanx, Nomand
Offline Jetsurly
So my 75 CB550F has 5 fuse places... does anyone know Aif they take the same amp fuse for each spot? I’m totally new to this bike and unfortunelty not in town but headed home. I was going to stop and get new fuses on my way. Help please!!  :)
The stock five position holders use the two outer position as spare fuse holders.
IIRC, the center position is the 15 A, the two adjascent are 7 A.
They are labeled on the fuse holder.
Offline Jetsurly
Thanks for the quick reply! The 15A fuse is missing and the one next to it (right side) is blown. That must be why my buddy couldn’t start it? And I just realized 15A means 15 Amps. (Face palm)
Offline Jetsurly
« Reply #10 on: August 17, 2018, 10:04:43 AM »
And SP mans spare. Oh man I need more sleep
« Reply #11 on: August 20, 2018, 08:18:32 AM »
Correct, to see the screen I need glasses to see the keyboard I need to take them off!!
