I have the clutch cable hooked up. I greased it with some fresh oil as well, and it is very slack, when I pull the clutch lever, it does not go back how it should. The clutch cable seems to be fine though after I greased it up, it moved freely inside the black housing. But when I hooked it up, it still just does not return how it should. There are no tight turns in the cable at all because I do not have it entirely in place, I'm worried it'll be worse once I tuck in the cable.
I think I might have hooked up the spring mechanism wrong inside the clutch cover, but it does seem to spring back ok, so that might not be the problem, I guess it isn't a very powerful spring.
Must I just get a new clutch cable?
