Author Topic: 1976 Barn Find Update. Ok How Do I Get Those Carbs Off??  (Read 3188 times)
saw750
« on: March 16, 2010, 03:37:22 PM »
So everything went by the book. Front fender. Front Caliper (lol the brake reservoir was filled with putty lol). Seat. Air box. Tank (full of lacquer, some rust and foul gas) No problems.
So what is the secret to getting those darn carbs to budge. I released the throttle cables. Loosened the carb/rubber retaining rings but the carbs dont move..
This was my last task of the day so I didnt spend all that much time messing with it...but there has to be right way and wrong way.
So i thought I better ask before I resorted to brute force. I dont see anything that should stop the assembly from slipping off.
so what am i missing??
thanks saw750
Offline kghost
Re: 1976 Barn Find Update. Ok How Do I Get Those Carbs Off??
« Reply #1 on: March 16, 2010, 03:40:27 PM »
Airbox is off?
Stranger in a strange land
Offline Johnie
« Reply #2 on: March 16, 2010, 04:29:06 PM »
Brute force and sometimes a hot air dryer to soften up the rubbers will help a lot. I had good luck with starting at one side and going from carb 1 - 4 sort of prying from left to right. Rather than trying to come straight back with all 4 at once.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline grandelatte
  • CB750K1-ish Frankenstein
    • Life is Xampericious!
« Reply #3 on: March 16, 2010, 04:41:55 PM »
i had to put the tie strap around the carbs and rear grab bar to pull the carbs off.
saw750
« Reply #4 on: March 16, 2010, 04:47:11 PM »
 nice photo. oh heck i like that idea! everything else has come off so smoothly. all the threads of every bolt have been clean and like new, then i hit those darn carbs and had to stop and think lmao
Offline bird
« Reply #5 on: March 16, 2010, 05:58:38 PM »
Have you got a Mack truck attached to those straps! Seriously, try squirting and soaking it all in WD40 and wait some time. Other guys are right too about applying some
heat, but not too much – burnt rubber sucks. Also, try some gentle but firm tapping with a rubber mallet: may loosen things up a bit. Good luck. ^^
« Reply #6 on: March 16, 2010, 06:11:52 PM »
Tip a kettle full of boiling water over the rubbers mate, and the carbs will come off fine. N.B., Make sure you're not standing with your feet under the bike when you do it..........  ;D
« Reply #7 on: March 16, 2010, 07:02:42 PM »
I am with Johnie  :D Schooled on this site but HEAT helps.Put your wifes hair dryer on HI or if you have a real heat gun warm them well and they will get a little more supple-------------   OOOOH   ---  HEY the boots  ;)
« Last Edit: March 16, 2010, 07:04:42 PM by ekpent »
Offline Steve F
« Reply #8 on: March 16, 2010, 07:05:01 PM »
I found that I first have to break the rubber parts free from the engine spigots with a large flat screwdriver, just lightly pry on the edge or end of the rubbers to break the bond.  After that, I stradle the bike, and push down on the whole carb rack and try to work it toward the rear, then pull up with the same rearward pressure, rocking them off the engine spigots up and down.
« Reply #9 on: March 16, 2010, 07:09:46 PM »
+ 1 on the up and down rocking,both for removing and installing. Wear some good heavy duty gloves also unless you like to give a little flesh to the HONDA gods  :'(     Hate those tabs------------
Offline Grnrngr
« Reply #10 on: March 16, 2010, 07:19:28 PM »
Not an unusual condition with rubber tubing thats been attached to a metal fitting for a LONG time...like radiator/heater core hoses and such.  At least you don't have to worry about crushing brass inlet/outlet pipes..
'72 CB750-K2 "PopCycle"
'73 CB750-K2 "Barney"
'77 CB750A
'83 Virago 500 (red)
'83 Virago 500 (black)
Offline Johnie
« Reply #11 on: March 16, 2010, 07:26:22 PM »
+2 on that one!!!
Oshkosh, WI  USA
« Reply #12 on: March 16, 2010, 07:32:08 PM »
Also when installing or removing,as you are pushing,lifting,rocking, and grunting,and making your wife worried  ??? while straddling your machine have it in first gear so it will not roll  ;)
« Last Edit: March 16, 2010, 07:35:52 PM by ekpent »
Offline jeepster
« Reply #13 on: March 17, 2010, 06:55:27 AM »
I used a claw hammer with a rubber coated handle and a little bit o wiggle.
"An ounce of prevention is worth more if you break it up into nickel bags."
« Reply #14 on: March 17, 2010, 09:30:42 AM »
all the above and some silicone grease to re-install. I think it helps slipping them on and sealing. Going on I have used a piece of wood over the carb faces and a pry bar through the frame on the wood. Be careful on 69 &70 cable type you can break the tie bar that holds them together.
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #15 on: March 17, 2010, 09:35:24 AM »
I just had this problem the other day. I wasnt clever enough to pry them off....I stood above the bike, grabbed either side of the carbs and pulled them up and down while cursing. The cursing helps. Got the job done.
saw750
« Reply #16 on: March 17, 2010, 12:21:33 PM »
i found that rocking method worked the best. lifted up the edges of the carb rubbers and gave them a shot of triflo and wiggled and rocked and they slipped right off! thanks folks!
