Author Topic: GOD#*&N OIL LEAK... does anyone have 650 cylinders on the shelf? Soos?  (Read 4280 times)
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
Re: GOD#*&N OIL LEAK... does anyone have 650 cylinders on the shelf? Soos?
« Reply #25 on: April 08, 2010, 01:39:27 PM »
Thanks, bryan. The impregnation sealing will cost me $15-20 if I can get it into another batch, so this is clearly the way to go. It'll cost me more to ship it than to have the sealing done.   ::)
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline paulages
  • 1976 cb735
« Reply #26 on: April 10, 2010, 09:22:51 PM »
well, i found my smoking gun. with the sleeves removed, oil stains are clearly visible in the sleeve bores exactly where the leak seems to be coming from. i ran the block through the dishwasher a few times, and the porosity became very visible when cleaned up. hopefully the impregnation sealing will be the cure.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
« Reply #27 on: April 10, 2010, 09:52:58 PM »
Yikes I hope so too for your sake.
Would it not be worth it while the sleeves are removed to also machine a new groove in the bottom of the bores for o-rings?
Offline paulages
  • 1976 cb735
« Reply #28 on: April 11, 2010, 12:45:53 AM »
i think there's enough room for an o-ring of the right cross section. the sleeves have a taper already. maybe someone can tell me, as I can't remember and don't have an engine open: is there actually a lip machined for the o-ring, or does the o-ring just fit between the taper and the bore? i believe it's the latter, right?
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
« Reply #29 on: April 11, 2010, 05:28:59 AM »
I don't have any 650's but the 500's & 750's have a notch machined in the block for the ring.
I should stay quiet now because I can't remember...you used 750 sleeves with a tapered bottom, maybe the 650 cylinder is taller? In a stock 750 the sleeve taper begins 10mm or so below the block surface.
Offline paulages
  • 1976 cb735
« Reply #30 on: April 11, 2010, 02:49:18 PM »
i had the sleeves machined down to the same exterior dimensions.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
« Reply #31 on: April 11, 2010, 11:41:10 PM »
The geriatric grey cells tell me they all have a counterbore in the alloy block that the "O" ring is a @stard to get into
Offline paulages
  • 1976 cb735
i have some pictures of the smoking gun before i send it off to be sealed..
lots of holes!  :o
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline bikebitzofvt
Are those pics with the liners removed?  I read back a little farther and confirmed the answer myself :)
Seems to me some where around the late 70's Honda's aluminum casting quality went dramatically down hill...
While the sleeves are out would it make sense to add some o-rings to the base?
BTW  - that pic of the 400F is kinda cool in an artsy way...
Glad you found your culprit!
"If it ain't broke you aren't riding it hard enough!"
77 CB750K7, 77 KZ1000B
Geezus, if anyone ever says anything bad about my RC big block's crap casting, they should refer back to your pics Paul! Can the impregnation sealer handle the heat? Cheers, Terry. ;D
Offline cb650
Hel l  just have one made out of billet.   ;D
Offline paulages
  • 1976 cb735
as far as i know, terry. they seemed quite familiar with this dilemma. it will be o-ringed as well, so hopefully it won't be an issue either way.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline paulages
  • 1976 cb735
Ok, got the cylinder block back and painted and the liners installed. i shipped the part out last friday, and had it back at my shop wednesday. now that's quick turn around!
it had a powdery film on it, so i ran it through the parts washer. when it came out, the entire surface was darker than bare aluminum. you could tell that the sealer had really soaked into the aluminum, which porous to begin with even with a well cast surface. just waiting for cometic to get my gasket to me and it's back together!
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline Frankenkit
  • Industrial Strength
Good luck, Paul! Hope this solves all your problems!
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
How is it applied Paul? Pretty cool, I hope it works for you too.
Offline paulages
  • 1976 cb735
they put the part in a chamber, which is depressurized to a -26 PSI vacuum. the chamber is flooded with the sealant, which is sucked into every pore in the part, then the chamber is flushed with water and the part cured with 180F water. it is obvious from the surface how well the sealant is drawn into the metal. it adds zero thickness to the surface, but fills any open pores.
machining for an o-ring would cost me $100... i hope i'm not making a mistake by relying on this process and a sealer at the base, but i'm going to try. at least this way if it still leaks i know that the process didn't work.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
