Author Topic: Brake Light only works with rear brake. Where to start?  (Read 768 times)
Offline njcafe84
« on: March 17, 2010, 02:51:39 PM »
My brake light will only work when the rear is used. Where should I start looking for problems? Any suggestions?
Re: Brake Light only works with rear brake. Where to start?
« Reply #1 on: March 17, 2010, 02:56:07 PM »
Check the wire diagram for your bike.
...and the front brake light switch.
Offline Bodi
« Reply #2 on: March 17, 2010, 03:09:20 PM »
I think they all came stock with hydraulic pressure switches for the front brake light. This is mounted on a machined block on the triple tree, follow the hose from the master cylinder and it goes directly to the switch block. The switches sometimes fail but maybe a wire has just fallen off. The two wires on the switch go into the headlight shell and join the main harness in there.
Modified braking systems should have some brake light switch on the front. Often a master cylinder with a mechanical switch is used, sometimes a "switch banjo bolt" is used, usually on the master cylinder outlet.
Offline OApb
« Reply #3 on: March 17, 2010, 06:09:44 PM »
My bike did the same thing. Turns out the front switch, which is mounted in the brake lever perch and is actuated by the lever itself had come loose and was pushed out of the hole it sits in. Might check that
Offline njcafe84
« Reply #4 on: March 17, 2010, 07:39:47 PM »
ok guys thanks for the advice. Ill check it out tomorrow
