Author Topic: IC's Interesting LED Gauge Lighting  (Read 59791 times)
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
Re: IC's Interesting LED Gauge Lighting
« Reply #100 on: April 09, 2010, 08:40:21 AM »
The ring is powered by 12v that goes into eight 129 ohm resistors (dropping 12v to 9v) each
resistor powers a group of three 3v LEDs.
Formosa41
« Reply #101 on: May 09, 2010, 11:08:37 PM »
I have a related question....I had to take the mph gauge apart anyway because one of the little black screws vibrated out and the face was sitting at an angle. So since I was in there anyway I would like to print up a new face for it......Only thing is, I have no  idea how to pull the needle off so I can take the face off to scan. I tried to pull it off but it seams pretty firmly attached. Is that all I need to do is pull harder? Its for a cb350f if that makes a dif.
Offline Zaipai
    • My Home page
« Reply #102 on: May 10, 2010, 05:26:38 AM »
What many do, and it worked pretty nice for me once, is use two spoons, and put one on each side of the needle and pry up. They are not held on by much so its probably just some friction holding it down. Using the spoons is nice because it tends not to bend the needle.
.: Scott :.
Its my Avatar..
75 CB550F  |
  • Like a well oiled
    • Undead Asphalt
« Reply #103 on: May 10, 2010, 05:27:36 AM »
just pull harder.  I pinched mine off.
if you're worried about bending it take a pair of cheap little tweezers and center them up under the strongest part of the needle so you can have a stronger object to pull on.
Offline Old75_ratafe
  • CB750 Cave Spelunking
  • 1975 CB750K
« Reply #104 on: May 10, 2010, 02:36:19 PM »
.: Scott :.
God I idea I do see one potential problem though... I know it would be my luck if I did the spoon thing it would just fly across the room and the gnomes who steel my screws and stuff that fall would immediately grab it and run off... damn gnomes
1975 CB750K
Project Back in Black
Offline BlindJoe
« Reply #105 on: May 10, 2010, 02:41:17 PM »
lay a cardboard box on its side with a towel in it and do it in there
  • 1975 CB750K
« Reply #106 on: May 10, 2010, 03:00:56 PM »
True.... But gnomes can get through cardboard... although the towel might slow them down enough...  ;D
1975 CB750K
Offline Zaipai
    • My Home page
« Reply #107 on: May 10, 2010, 04:42:31 PM »
You dump some important looking screws in the corner under a bench, and while the gnomes are busy grabbing them remove the needle and pick it up. Works for me! ;)
Course that could be the beer talking..
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline BlindJoe
« Reply #108 on: May 10, 2010, 08:43:02 PM »
this might work......
Offline Zaipai
    • My Home page
« Reply #109 on: May 11, 2010, 04:42:39 AM »
I like it Blindjoe, can I just pick that up at any Home Depot?  ;D
.: Scott :.
Its my Avatar..
75 CB550F  |
  • 1975 CB750K
« Reply #110 on: May 11, 2010, 10:47:22 PM »
Hmmm I like it.
1975 CB750K
  • Like a well oiled
    • Undead Asphalt
« Reply #111 on: May 12, 2010, 05:27:03 AM »
sweet lord, people!
;D
  • 1975 CB750K
« Reply #112 on: May 13, 2010, 09:45:47 PM »
sweet lord, people!
;D
What ya act like we jacked your thread to discuss our terrible gnome problem  ;D
1975 CB750K
  • Like a well oiled
    • Undead Asphalt
« Reply #113 on: May 14, 2010, 08:06:22 AM »
 ::)  :D :D
Offline jaguar
« Reply #114 on: May 14, 2010, 02:25:14 PM »
if you were to use the ccfl set up where would you mount the inverter/power supply?
  • Like a well oiled
    • Undead Asphalt
« Reply #115 on: May 14, 2010, 06:49:15 PM »
between the tank and the frame?
Offline jaguar
« Reply #116 on: May 14, 2010, 06:58:28 PM »
not really sure how big the unit would be
do you think that the ccfl is that much better?
  • Like a well oiled
    • Undead Asphalt
« Reply #117 on: May 15, 2010, 05:57:26 AM »
i don't know, I think it would outlast the individual Chinese LEDs.
  • 1975 CB750K
« Reply #118 on: May 15, 2010, 11:34:21 PM »
Most of the ones I've seen are pretty small.  Say 3" L x 1" W x 1/2" thick.
1975 CB750K
Offline cameron
« Reply #119 on: May 15, 2010, 11:42:20 PM »
I have been reading this thread lately...
and then I went for a ride last night, and both of my gauges were totally dark!
Since I have to get into them anyway... I ordered a pair of halos.
Thank you for the wonderful idea.
1976 CB550F
Offline jaguar
« Reply #120 on: May 16, 2010, 07:33:30 PM »
what size ring would you use in a set of cb350F gauges?
  • Like a well oiled
    • Undead Asphalt
« Reply #121 on: May 17, 2010, 06:46:26 PM »
same.
Offline jaguar
« Reply #122 on: May 17, 2010, 07:48:03 PM »
wasent sure as i thought that the CB350F gauges are smaller
the box on the ccfl lights is 2.75x1.1  not sure of the third demetion...lol
they also said that one inverter can light both rings
Now i need to figure out how to get new faces in my gauges.
Offline Kframe
  • Life is good!
« Reply #123 on: May 17, 2010, 09:54:27 PM »
I've been googling and reading up on various options, and one thing that's pretty interesting is flexible, cut-able electoluminescent panels.  They're more $$$ than LED rings, but give even cool lighting, and would look awesome I think.
http://www.luminousfilm.com/el_lamp.htm
ebay link
Search for "EL backlight" and you'll find gobs of info.
I'm still trying to find ready made circular ones, would seem a better option than cutting rectangular pieces.
-K
2007 Triumph Bonneville T100, ARK'd, Pods, TOR's, Napoleon's, Innovate G5 Air/Fuel Gauge, Ignition Relocation by D9, Stebel Nautilus, Avon Roadriders
1984 Honda Shadow VT700c, Stock
1974 Honda CB550K, In rehab
1986 Honda Helix
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #124 on: May 18, 2010, 02:08:58 AM »
I've been working with these flexible LED strips lately.  I haven't put one onto a gauge yet, but the 9-inch looks to be about right.  They can also be cut in groups of three.
http://www.oznium.com/led-flex-strips
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
