Author Topic: IC's Interesting LED Gauge Lighting  (Read 61103 times)
Offline brettster26
Re: IC's Interesting LED Gauge Lighting
« Reply #225 on: August 25, 2011, 11:52:35 AM »
Quick Question... I asked previously how you would connect these, the easiest way looks like with the empty basis, but there are 2 different kinds BA15 Adapter and the empty base,  Just trying to visualize how these would work for the two wires coming off the LED lights.
Thanks
Offline DJ_AX
« Reply #226 on: August 25, 2011, 04:58:25 PM »
This mod is on my winter list for sure! Looks great!
Thanks ....
Offline -CB-Jamie-
« Reply #227 on: August 26, 2011, 04:30:05 AM »
Thanks
Well what I did which I think is the easiest was just replaced the wires coming off the LED strips with longer ones, put heatshrink tubing on them and brought them down into the headlight bucket and put bullet connectors on them and plugged them straight into the connectors on the harness. I brought the wires out through the holes where the bulbs would normally be in the gauge and used silicone to seal them which is easily removed if ever required. So I was just basically left with a gauge and two wires coming out of it.
You can kinda see how long I left them in this pic
72 CB350/4
76 CB400/4 CB400f "Project Resurrection"
77 CB550/4 1977 CB550 Yet Another Cafe
77 cb200
09 cbf600
Offline cameron
« Reply #228 on: August 26, 2011, 12:16:08 PM »
That totally works.
I ised lamp bases so that I could take it on nd off, and maybe even resort it to stock without any trouble.
Not that I will restore it to stock after seeing it :)
1976 CB550F
Offline brettster26
« Reply #229 on: August 29, 2011, 09:54:28 AM »
Any pictures of how you used the lamp basis?  I was going to try that, but not sure how they work.
Thanks
Offline brettster26
« Reply #230 on: August 29, 2011, 10:30:49 AM »
Also What Gauge Bullet Connectors would be used to replace all the old ones?
Thanks
« Reply #231 on: August 29, 2011, 11:20:25 AM »
Offline cameron
« Reply #232 on: August 30, 2011, 12:01:25 PM »
Thanks
No pics... but I actually didnt buy blank bases... I took my old bulb out, broke the glass and ground out all the shards and stuff with a little screwdriver. Then there were two small solder points that I wired her up to. One on the edge, one in the middle.
It is really easy if you understand even the most basic of circuits, which I imagine you do. Its just fine soldering. Red to the middle, Black to the edge... thoug I doubt it matters.
If I pull them out any time soon, I will snap a pic.
1976 CB550F
Offline brettster26
« Reply #233 on: August 30, 2011, 08:20:55 PM »
To replace the wires off the LED halos what would be the correct gauge wire?  Thanks new with this electric stuff and figure i could use the wire info if needed when connecting the wire harness?  I have a 1975 CB550
Thanks for all the info on this subject!
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #234 on: August 31, 2011, 09:27:46 AM »
You wouldn't need very thick wires  at all, maybe 18 ga at thickest.  Those led's don't draw much current at all, so I wouldn't worry about using anything thick...
Offline srbakker
  • Spam & Eggs
« Reply #235 on: January 22, 2012, 08:25:43 AM »
Inspired by this thread and my ratty old gauges, I laid into my own gauge project.  Sorry - some of the photos are quite large.
Starting point:
Stripped and with LEDs epoxied in place.  You can see that I just used one set of rubber light boots and ran the wires through a hole in the bottom.  I soldered them up to the existing wiring and covered them in heat wrap as well.
Christmas presents from my wife!
Finished product.  Joker Machine didn't send enough of those stupid gold allen screws so I'm waiting on 2 more for the tach.
And last but not least - night light.
1975 CB750 K5
2007 Triumph Tiger
2007 Triumph Speed Triple
1971 Kawasaki F7 175 Enduro
Offline -CB-Jamie-
« Reply #236 on: January 22, 2012, 12:28:09 PM »
Lookin pretty sweet, I like. Those clamps that bolt the gauges back together are pretty handy, makes it a lot easier than trying to get that chrome ring back on I'd say.
72 CB350/4
77 cb200
09 cbf600
Offline Old75_ratafe
  • CB750 Cave Spelunking
  • 1975 CB750K
« Reply #237 on: March 22, 2012, 11:35:15 PM »
Looks cool and I do like their stuff... but good god their #$%* is expensive!  $170 for two rings and two plates.... Just can't justify putting that on my old rat.
1975 CB750K
Project Back in Black
Offline Toxic
« Reply #238 on: March 23, 2012, 03:57:02 AM »
I'd say looks killer and you obviously have yourself a great wife.
Offline srbakker
  • Spam & Eggs
« Reply #239 on: March 23, 2012, 08:53:18 AM »
Yes, yes, I do.  ;D
1975 CB750 K5
2007 Triumph Tiger
Offline Lostboy Steve
« Reply #240 on: March 23, 2012, 11:57:32 AM »
Is it blinding at night? I used those led halo rings in my Buell headlight and the leds were brighter than the HIDs. I hate having the cluster super bright at night, however I have a sensitivity to light.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline srbakker
  • Spam & Eggs
« Reply #241 on: March 23, 2012, 02:56:34 PM »
Dunno yet.  That's bench tested and attached to one of my Triumph batteries, since the CB750 is basically a pile of parts right now.
1975 CB750 K5
2007 Triumph Tiger
Offline cameron
« Reply #242 on: March 23, 2012, 05:11:36 PM »
Mine are totally the perfect brightness.
As you can see, they are pretty close to the same brightness as my Neutral light....
« Last Edit: March 23, 2012, 05:13:17 PM by cameron »
1976 CB550F
Offline fisdan
« Reply #243 on: March 23, 2012, 11:29:49 PM »
Hello
know someone a website where you can buy the flex joint rings which can be used for speedy?
They looking super nice 
Offline Harsh
  • 74 CB750 and two 72 CB350's
« Reply #244 on: January 04, 2013, 11:40:47 AM »
So.. I forget which product number it is exactly... so you would have to do some measuring.. but I think this would totally do the trick:
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fspecs%2FG4BP-G4-adapters.htm
I hate to bring up an old post, but I am about to dive into my gauges and I have questions about this base.  I would like to pressume that you just plug the wires into one of the holes on the base, but I am not sure.  I don't want to hack into my wiring and want to be able to keep the rubber plugs intact so this looks like the best fit for my application.  Did anyone ever figure out if this is the correct blank for our bikes?
« Reply #245 on: January 04, 2013, 12:18:14 PM »
you need the BA9S base.  it is a direct fit.
the one above is the BA15.  (its too big)
superbright also sells ba9s bulbs that do a great job.
<====see my gauges  ;)
I replaced everyone of my gauge and tree lights with these for just a few bucks.
http://www.superbrightleds.com/moreinfo/led-vehicle-replacement-bulbs/ba9s-led-bulb-1-led-wide-angle/3/
« Last Edit: January 04, 2013, 12:23:05 PM by flybox1 »
Offline Harsh
« Reply #246 on: January 04, 2013, 12:28:08 PM »
Thanks for the info.  Was I correct in my assumption that you would just press the wires into the base?  You also answered another question I was pondering about the tree lights.
« Reply #247 on: January 04, 2013, 12:31:58 PM »
yes, sorry, they do just press in.
Offline Harsh
« Reply #248 on: January 14, 2013, 04:36:54 PM »
Well I ordered some 80mm rings for my 74 750K and they are too small.  They won't fit around the trip reset gear.  So I am going to try some 90mm rings.
And I didn't see any of the BA9S bases on super bright LEDs site.
« Reply #249 on: January 14, 2013, 05:33:51 PM »
On their site, search for universal led kit. One is included in the $14 kit...or you can order any $.50 ba9s bulb and tear out the guts and solder your own....
« Last Edit: January 15, 2013, 10:36:16 AM by flybox1 »
