Author Topic: I can't figure out the music for this bump!? MYSTERY SOLVED!!  (Read 4380 times)
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
Re: I can't figure out the music for this bump!? MYSTERY SOLVED!!
« Reply #50 on: April 06, 2010, 12:24:40 PM »
I don't mean to be a jackass, but the original bump is identified in the title... or did you add that later?
yes I added that later. ya goof :D
Offline fastbroshi
  • Puppet
« Reply #51 on: April 06, 2010, 12:33:56 PM »
OMG that #$%* is funny, especially when you just see the lady on the phone go down and the tree gets sprayed with blood.
Just call me Timmaaaaay!!!
Offline BlindJoe
« Reply #52 on: April 06, 2010, 12:40:31 PM »
Terry's worst nightmare!
  • Like a well oiled
    • Undead Asphalt
« Reply #53 on: April 06, 2010, 01:03:10 PM »
that whole movie is hilarious.
  • Like a well oiled
    • Undead Asphalt
  • Like a well oiled
    • Undead Asphalt
« Reply #55 on: April 28, 2010, 07:49:24 PM »
Maybe it's just my computer, but every time the kick drum is hit, there is this kind of volume-suck/cancelation thing that happens.  Is that part of the tune?
this song does that too.
Offline Frankencake
  • Yesssssss,
  • "I like the old junk"
« Reply #56 on: April 29, 2010, 07:08:53 AM »
That's just a weird effect to include in a song.  It just sounds like mechanical failure from amps that are too underpowered, as in the input voltage in inadequate.  I've created that effect by using weak(er) batteries in a distortion pedal.  The op amps pull to much power when trying to amplify low frequencies.
333:  Think "Shakeweight".
Offline Frankencake
  • Yesssssss,
« Reply #57 on: April 29, 2010, 07:11:58 AM »
I swear that you can hear a goat or a sheep bleating in this song.  Listen closely.
  • Like a well oiled
    • Undead Asphalt
« Reply #58 on: April 29, 2010, 07:26:43 PM »
I know, isn't it cool.
when you make the 'on four loop' in a music editor, you drop the gain in time with the bass, on the block that holds your midrange and high end. does the same as running a .5v pre-out into a 1200 watt amp.;D
makes it sound like you're listening to it in a dance club.
you should hear it in a good set of headphones! :o
« Last Edit: April 29, 2010, 07:28:33 PM by Industrial Cafe »
  • Like a well oiled
    • Undead Asphalt
« Reply #59 on: April 29, 2010, 07:40:01 PM »
beep boop.
Offline DammitDan
  • Prodigal Son
  • It lives!
« Reply #60 on: April 29, 2010, 07:40:20 PM »
Actually it's an effect of overcompression.  It's usually a sign of a poorly mixed/produced song.  Unless you're using as an effect  ;)
You run the entire mix through an audio compressor and turn the kick up so it's louder than everything else.  Set the compressor's threshold so that the only thing that goes over it is the hot kick track and set the attack and release down to tenths or hundredths of a second.  When the kick hits it activates the compressor which turns down everything in the mix for 1/20th of a second.  Gives the whole mix a "whoomp whoomp" kinda feel.   ;D
I personally can't hardly stand that sound, since I was trained that it's something to avoid like the plague!
CB750K4
  • Like a well oiled
    • Undead Asphalt
« Reply #61 on: April 30, 2010, 06:57:34 AM »
     That's why I think it's cool; almost nobody does it.
like wearing a fedora instead of a baseball cap.
Offline DammitDan
  • Prodigal Son
  • It lives!
« Reply #62 on: April 30, 2010, 10:11:31 AM »
Well the T-Pain AutoTune phenomenon was started by Cher in much the same vein...  It was originally a "mistake" for the autotune effect to show through (since it's supposed to be transparent; singers are supposed to be able to sing without the aid of a machine!)  Cher heard the mistake and thought it sounded neat, so she used it in her song "Believe".  The one that goes, "Do you beeelieeeeve in life after love".
One man's production trash is another man's production treasure!
CB750K4
  • Like a well oiled
    • Undead Asphalt
« Reply #63 on: April 30, 2010, 06:45:20 PM »
yeah, I remember the controversy well.
Offline Damfino
« Reply #64 on: April 30, 2010, 06:47:50 PM »
I still think it was written by your mom....
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
  • Like a well oiled
    • Undead Asphalt
« Reply #65 on: April 30, 2010, 07:07:21 PM »
in a thong.
Offline Laminar
  • Retsam
« Reply #66 on: May 01, 2010, 10:15:25 AM »
The only people that wear fedoras are douchebags that think they're being unique.
And old men.
  • Like a well oiled
    • Undead Asphalt
« Reply #67 on: May 01, 2010, 11:35:59 AM »
And old men.
I wear a fedora when I go outside 'cause baseball caps don't keep the sun off your ears.
        (I burn easily)
I also pop my collar to keep the sun off my neck.
but I get what you're saying about douche bags...  they always be jockin' my style.
