Author Topic: Need Front Wheel  (Read 454 times)
Offline nrd2052
Need Front Wheel
« on: March 20, 2010, 07:00:18 PM »
I know this may sound a bit strange but I am looking for an 18" wheel with a drum brake that will fit my 74 550. Any advice on something that will bolt in fairly easily?
Thanks!
Offline kevins750
Re: Need Front Wheel
« Reply #1 on: March 20, 2010, 11:11:29 PM »
I believe a CL350 had an 18" front wheel, pretty sure it would be 15mm axle...I would start checking for late 60's-70's for some drum front wheels..there are threads on axle diameters on here, do a search....
2003 YAMAHA ROADSTAR
1975 CB750F(build date 1/75 #313)
1978 CB750K
1973 CB750K(w/velorex sidecar)
Offline Kevin400F
« Reply #2 on: March 21, 2010, 05:46:35 AM »
Tell us a little more about your project, and what you're trying to accomplish.  Are you building a chopper or bobber, and want a small rudimentary drum for a clean looking front end, or are you buiding a old-school cafe racer or road racer replica and want a big, very functional drum brake with lots of stopping power?
I don't think typical  Honda CL350, CJ360, CB/CL450 OEM wheels will be a direct bolt-on since the 550 fork tube spacing is wider.  You might check out the CB400T Hawks. In any event, I believe you could mix and match axles and spacers to achieve a combination that will fit.
Offline nrd2052
« Reply #3 on: March 21, 2010, 07:30:32 AM »
I guess I would say that I am building one of my 550s into something that is just a little tougher than the stock 550 in looks, power and attitude. Currently the biggest mod has been the 650 engine swap (way easy, btw.)
I am looking for an 18 so I can run a tire that is the same size as the rear (looks only)
I am looking for a drum brake for a few reasons
1. Old Skool look
2. Cleans up the bars (no master cyl.)
3. my experience in riding all of the old hondas that I have tells me that the drums are better in most cases than the discs of that era for stopping power.
