Author Topic: Rotor hitting stator  (Read 1416 times)
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
« on: March 22, 2010, 05:36:05 AM »
Hoped to finish my S90 project yesterday, but when I kicked it over, there was a clatter. Removed the left cover and the rotor is touching the stator contacts. Front of vanes 180 degrees apart. Can see previous wear marks. Any ideas?  ???
Fonda Honda
Re: Rotor hitting stator
« Reply #1 on: March 22, 2010, 06:00:35 AM »
End of crank bent :(
Sam.
Offline grumburg
« Reply #2 on: March 22, 2010, 06:35:48 AM »
Dial indicator shows 0 runout at crank
Fonda Honda
« Reply #3 on: March 22, 2010, 06:43:44 AM »
Seeing as the rotor is on a tapered shaft, I wouldn't think it could not go on correct.
Is the stator mounted correct, might it have been damaged when you aquired the bike?
Sam. ;)
« Reply #4 on: March 22, 2010, 08:06:15 AM »
Locating dowel (s) missing?
Offline TomC
« Reply #5 on: March 22, 2010, 03:03:41 PM »
Hi BryanJ & Group
     There is no locating dowel (s). The dowel on the Super 90 stator is a stop for the cam chain guide roller. The stator is located by the fit of the outer diameter of the stator into the left crankcase.
     If the rotor is spinning true I would check that the stator is seated properly and not bent.
     TomC in Ohio
TomC in Ohio
76 CB750 F1 Daily Rider
76 CB550 stalled project
76 CB400F Injured Reserve
