It depends on how you ride the bike. If you never let the engine run below about 3000 RPM, you'll probably be OK.
If your remove some other electrical loads from the stock bike, that will help.
The alternator only makes about 50 W at idle, and the stock bike consumes 110-ish watts whenever the key switch and lights are on. The difference is made up by what is stored in the the battery, so it depletes at about a 60 watt rate at idle. When the engine is revved to 5000 RPM the alternator can make 150 watts, with about 40 watts available to restore the battery at that RPM.
The 3 ohm coils may draw 20-40 watts more than the stock 5 ohm coils, leaving little available to recharge the battery.
The 750's 210 watt alternator can take the extra load of 3 ohm coils. The 550, not so much, without major changes in lighting load reduction.
