Author Topic: 17mm bolt??  (Read 4593 times)
Jim Shea
17mm bolt??
« on: January 19, 2006, 04:23:35 AM »
I seem to remember that I was advised to change an old bolt to a 17 mm bolt when I next change the oil!
Which one is it and why would this be better??
I could see changing the sump drain bolt for a new one as this is fairly worn, but the only one I can see on DSS is an oil filter bolt with 17 mm head for 8 pounds!
Jim.
Offline eurban
Re: 17mm bolt??
« Reply #1 on: January 19, 2006, 04:42:47 AM »
Can't be sure what the advice was at the time but my guess is that it was refering to the oil filter bolt which Honda originally provided with a smallish 12/13mm (or so) head.  They were worried about people over torqueing so they gave you a small bolt head in the hope  of avoiding this.  A steel bolt in an aluminum case can get locked in pretty good so often times these little bolts heads get roached in the removal process.  The 17mm bolt gives you a more reliable grip . . .just don't overtorque it. I also put a tiny bit of sieze compound on its threads prior to installing.  I think that this is good practice on any bolt where you are mixing metals, or in the presence of high heat or both.  This bolt is pretty commonly available in the aftermarket so you might be able to find it cheaper than at DSS.
Jim Shea
Re: 17mm bolt??
« Reply #2 on: January 19, 2006, 04:45:28 AM »
Thanks. I thought it might be the filter bolt.
Offline Jonesy
  • Shop Rat
Re: 17mm bolt??
« Reply #3 on: January 19, 2006, 06:36:34 AM »
A 17MM oil filter bolt makes it nice when changing the oil since the sump and tank drain plugs are also 17MM. This way, only one wrench (or spanner) is needed.
Offline Bob Wessner
  • "Carbs Suck!"
Re: 17mm bolt??
« Reply #4 on: January 19, 2006, 06:39:21 AM »
Yup, found that to be one of Honda's handier decisions.  :)
Jim Shea
Re: 17mm bolt??
« Reply #5 on: January 19, 2006, 06:44:54 AM »
I will get a 17mm and a new sump bolt for the next oil change.
Offline Gordon
  • 750K1, 550K2
Re: 17mm bolt??
« Reply #6 on: January 19, 2006, 07:00:26 AM »
While we're on the subject of bolt sizes;  what's with the 17mm size anyway?  You see plenty of 8mm, 10mm, 12mm, and 14mm, and then 17mm? ???  Was there just some universal understanding long ago to split the difference between 16 and 18mm to reduce the number of wrenches needed?
Just drinking thinking too much, I guess. ::)
Jim Shea
Re: 17mm bolt??
« Reply #7 on: January 19, 2006, 07:20:15 AM »
I assume it was because the sump bolt was already 17mm?? are there any other 17mm bolts on the bikes??
Offline Jonesy
  • Shop Rat
Re: 17mm bolt??
« Reply #8 on: January 19, 2006, 07:25:34 AM »
...or why they go 8, 10, 12, 14, then 17, 19, and then 22mm (rear axle nut)?
...or why car companies use 8, 10, 13 and 16mm, etc ?
Offline Gordon
  • 750K1, 550K2
Re: 17mm bolt??
« Reply #9 on: January 19, 2006, 07:38:20 AM »
Some of the engine mount bolts are 17mm as well.
Re: 17mm bolt??
« Reply #10 on: January 19, 2006, 07:52:41 AM »
There is somwhere a "standard" on prefered sizes for bolts--unfortunately the japanese rarely read these documents hence the 12mm spanner size on a 6mm thread Ford happily use 15 and 16mm spanner size bolts!
Offline Gordon
  • 750K1, 550K2
Re: 17mm bolt??
« Reply #11 on: January 19, 2006, 08:07:41 AM »
I'm not sure about the newer models, but over here Ford and all the other American car makers still use the old standard fractions-of-inches size bolts and nuts.  That's one of the reasons I keep buying Japanese cars, because I got most of my tools when I had an old VW that used metric sizes and there's no way I'm shelling out the dough for a whole new set of wrenches and sockets!
Offline scott_cb650
Re: 17mm bolt??
« Reply #12 on: January 19, 2006, 09:47:38 AM »
Isn't the spark plug 17mm also?
Why worry about tomorrow for tomorrow has enough troubles of it's own.
Offline Gordon
  • 750K1, 550K2
Re: 17mm bolt??
« Reply #13 on: January 19, 2006, 09:53:57 AM »
The spark plugs are 18mm.
Offline Gordon
  • 750K1, 550K2
Re: 17mm bolt??
« Reply #14 on: January 19, 2006, 10:05:26 AM »
I think the plugs sizes are based on the the thread diameter, and yes it is confusing. :-\
Offline volz1fsu
Re: 17mm bolt??
« Reply #15 on: January 19, 2006, 10:20:48 AM »
Where can one of these 17mm Oil filter bolts be had? Already ruined the 12mm end on mine, vice grips work but ruin it more.
Online SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: 17mm bolt??
« Reply #16 on: January 19, 2006, 10:31:03 AM »
You can get them from David Silver Spares
www.davidsilverspares.co.uk
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline Jonesy
  • Shop Rat
Re: 17mm bolt??
« Reply #17 on: January 19, 2006, 01:09:24 PM »
JC Whitney sells them too. I have one on my bike and it's been good.
    • TVAM
Re: 17mm bolt??
« Reply #18 on: January 19, 2006, 11:44:30 PM »
Maybe 17mm is the closest equivalent to one of the imperial sizes?
Same with 13mm?
Just a thought.
SOHC4 Member #2393
2015 Tiger 800 XRT
Offline mcpuffett
Re: 17mm bolt??
« Reply #19 on: January 20, 2006, 01:43:03 AM »
14 mm is close to 9/16 if thats any help   :-\ ???  mick.
Jim Shea
Re: 17mm bolt??
« Reply #20 on: January 20, 2006, 01:52:38 AM »
Was the bolt bought from Whitney a 'Honda' bolt or just any old 17mm bolt?
Offline Raul CB750K1
Re: 17mm bolt??
« Reply #21 on: January 20, 2006, 07:35:55 AM »
Do an eBay search, you will find a bunch.
Raul
