Author Topic: rear brake switch question  (Read 1659 times)
exdrocca
« on: January 19, 2006, 01:56:31 PM »
I was just wondering if the rod on the rear brake switch, that is attached to the spring, supposed to move in and out? It's for a '74 CB 750. As of right now it doesn't really move in and out.
Thanks for your help.
Offline Bob Wessner
  • "Carbs Suck!"
Re: rear brake switch question
« Reply #1 on: January 19, 2006, 02:03:15 PM »
Yes, it should, this actuates the brake light. When you say it does not move, is that using the brake pedal? Can you move it at all by hand?
exdrocca
« Reply #2 on: January 19, 2006, 02:06:48 PM »
no, I can't move it by hand. I guess it's all clogged up. You think it's possible to fix it?
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: January 19, 2006, 02:09:27 PM »
Not sure, perhaps someone else can answer. Might be corroded inside or something. Might be worth considering a replacement (if avail.) considering its a safety issue.
theunrulychef
« Reply #4 on: January 19, 2006, 02:25:11 PM »
$4 over at Parts N More.  It's about halfway down the page.  I replaced mine about a year & a half ago with theirs & it's worked great ever since.  I think there's a $35 minimum order, but I'm sure there's something else that you might want & the shipping is free to the US.
Good luck,
-Jay in Philly
Offline Gordon
  • 750K1, 550K2
« Reply #5 on: January 19, 2006, 02:40:28 PM »
Cycle-Re-Cycle has them as well, and no minimum order.
exdrocca
« Reply #6 on: January 19, 2006, 02:42:14 PM »
thanks unruly. I got the switch to move up and down, but now have discovered that both my front and rear brakes do not actuate the taillight. Would the motor have to be on to make them work? This bike has been a winter project, and it's finally gonna be ready for this weekend, so I haven't really noticed that they don't work til now. I have checked the connections at both switches and also the fuses, but I'm stuck, and don't have a manual handy. Any ideas where else I should start looking?
Thanks again.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #7 on: January 19, 2006, 02:44:50 PM »
Two different switches actuate the brake light (front vs. rear). Though I guess both switches could be bad, I would check to see if the brake light bulb is good first.
Forgot to add, no, motor does not need to be running. Just need the ignition turned on. One other possibility is dirty/corroded connections elsewhere in the harness. They may need cleaning if the bulb turns out to be OK or a replacement bulb still does not work.
« Last Edit: January 19, 2006, 02:51:57 PM by Bob Wessner »
« Reply #8 on: January 20, 2006, 09:17:41 AM »
Got loads of pattern rear brake light switches $15 inc air shipping to US PM me if you are interested
Offline 78 k550
« Reply #9 on: January 20, 2006, 02:56:40 PM »
Did you check the bulb? easy thing to overlook.
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline toycollector10
« Reply #10 on: January 20, 2006, 08:15:34 PM »
This is a less than $10 part. The spring and slider in mine were a bid jerky and rusted, shorted somehow and blew the main fuse. It's a quick fix for peace of mind.
1969  CB 750 K0
1973  CB175
1973  Z1 Kawasaki
