Author Topic: CB750 890cc Engine build [Codename: Rattlesnake]  (Read 66099 times)
Offline michrobi
  • Goldenrod blew a 5" hole out the front with a
  • On a neverending quest for more garage space
Re: CB750 890cc Engine build [Codename: Rattlesnake]
« Reply #200 on: September 13, 2010, 05:26:10 PM »
Oh yeah, I might have turned it three total rotations so far is all. I don't have any visible wear, but I noticed spots in the bearing faces when I cleaned them off the first time that I assume are from the moly being squished. I used only straight oil on the following two tries.
I'm keen to hear back if you or Ron have any issues when you torque to 20+ lbs. on the studs.
-Mike
'78 CB750F All stock except for the powerplant. Jived it off my Dad in the spring of '94. He had it since 1980 and it's the first bike I ever rode on.
Current project: http://forums.sohc4.net/index.php?topic=67756
How's them SOHC4 patches coming?
Offline michrobi
« Reply #201 on: September 13, 2010, 05:31:00 PM »
Mike, sounds like I can hold on to the carb sync tool a bit longer..... J/K
that blows, if you need a hand just let me know.
I was close to giving you a buzz Saturday to see if you wanted to come put eyes on it and make sure I wasn't jacking something up, but I figured since you're an old duffer with a hurt back and all I shouldn't bother ya.   :D
All BS aside, you should come look at it and see what's happening man. I'm sure it's fat bearings, but on the other hand I never have heard of clamping a crank... even with blacks.
-Mike
Offline tweakin
  • tear down
« Reply #202 on: September 14, 2010, 05:26:31 AM »
Cool,  you going to be around this weekend?  I could stop by for a bit.
Offline michrobi
« Reply #203 on: September 14, 2010, 10:45:36 AM »
Actually, I'm in Vegas Friday morning till Sunday night. The new bearings will be a couple weeks though. Maybe during the week or next weekend you could roll up.
-Mike
Offline tweakin
  • tear down
« Reply #204 on: September 14, 2010, 12:04:49 PM »
Sounds good.  Enjoy Vegas.
Offline Tom
« Reply #205 on: September 15, 2010, 03:26:10 AM »
I completely cleaned the journals and bearings, then re-oiled and reproduced the same result three different times. Loosening the main studs from the clamped 20 lbs. to 17.5 lbs. or below releases the crank and the motor all turns normally. New bearings are ordered and will hopefully be here in less than the two weeks my bolts took.
Mike, try Torquing the bolts to 17 or so where the crank still turns freely then torqe one at a time to 20 and see if the crank nips up. this may show you the troublesome journal or bearing.
Tom
'59 T120.,'70 T120R Had one new.,'69 CB750 Oz Sandy Ruby Red.,'69 CB750 Oz Sandy Blue Green.,'70 CB750 K0 Candy Gold.,'71 CB750 K1 Valley Green I bought new.,'71 CB750 K1 Candy Garnet Brown.,'76 Rickman Honda CR750 R.C. Eng Cobra Powered. Two CB750 Choppers a Amen Saviour and a a Santee rigid arm Softail. A ‘72 Z1 Jaffa, and lotsa fun Honda Monkey bikes.
Offline michrobi
« Reply #206 on: September 15, 2010, 08:11:34 PM »
Hey Tom! How the hell are ya mate?    :)
What ever came of that case? Were you able to save it?
-Mike
Offline Tom
« Reply #207 on: September 16, 2010, 02:45:44 AM »
Hi Mike, I have been following your build with interest, what happened to that 812 idea you had way back? Your old cases arrived safe and sound Thanks... and better yet cost zero to ship over, as i got them sent with 4 bits of K0's i bought from Las Vegas. So all Good Mate and thanks for packing those cases so well... The saying goes the only thing they handle with care is a roll of barbed wire... and its true the K0 i got shipped over from North Carolina arrived with busted fins on the head and a busted alt cover, Man i was pissed, but after a month i am comming back around...and washed it up with some help from my buddy Bob, and its not looking so bad now..
I havent taken your old cases to the welders yet, but have had a good look and have noticed that that part of the front right side is very much the same like the die cast cases and i have dug out some old busted die cast cases to chop up for fill in bits, This is all my idea and the welder may well want to do something different as i will be guided by him... but my plan was to take up a good set of cases as well and let him bolt your damaged bottom half case to a good top case and fill in the missing bit using the cut out pieces and same with the Damaged Top case. sounds like it may work? I sure hope so.. I have most of the rest of the bike now too. all the right parts too... Hard to find stuff, i still have to find one sandcast speedo drive and that will be it... Wahooo..
Mike i have Gotta say your build is super sweet man.. and you have had me drooling and goo garing over your parts, hats off to you... Mike you are sure doing a great job well done... Tom...
Offline michrobi
« Reply #208 on: September 21, 2010, 03:38:17 PM »
Well I've had a lot of different ideas for this build along the way, but once Buzz made those 67mm JE pistons available, I knew I had to have them.  ;D
I'm sorry to hear the K0 got manhandled, that's the $h|ts mate. Sounds like you have a solid plan for the sandcast, my hat's off to ya.
-Mike
Offline tweakin
  • tear down
« Reply #209 on: September 21, 2010, 05:53:30 PM »
Hope Vegas was good!  I odered a Morgan carbtune last week.  I figured since I have two old bikes I will need my own carb sync tool rather than borrowing all the time.  Once your bike is done you are more than welcome to use it.  I can get your tuner back to you whenever.
Offline michrobi
« Reply #210 on: September 25, 2010, 02:32:29 PM »
Vegas was fun as hell! I even got some sun outta the deal.
So the greens arrived and I just plastigauged them with 20.5 lbs. on the studs. Guess what reading I got?... Yep .0015"
-Mike
Offline michrobi
« Reply #211 on: September 26, 2010, 05:01:07 PM »
Bottom end buttoned up. No problems.   ;D
-Mike
« Reply #212 on: September 26, 2010, 05:18:03 PM »
Twins  ;D Hope to get in some more time later in the week.
Offline tweakin
  • tear down
« Reply #213 on: September 26, 2010, 05:28:10 PM »
Awesome Mike!  If you need a hand, just let me know.  I am stoked the new bearings worked out.
Offline michrobi
« Reply #214 on: September 26, 2010, 05:36:39 PM »
Lookin awesome Jerry! I was afraid you had her started up already  ;D
Thanks Tige, my brother is in town Tuesday for a week or two so I'm not sure how much time I can scrounge up to work on it. I'll update when I have some progress.
-Mike
« Reply #215 on: September 26, 2010, 06:50:53 PM »
What everyone probably does not know is the extent to which we had to go to get all those nice pretty new bolts, etc  ;) Yeah, we're being anal  ::)
I've had visitors for the past 2 weeks and the only aluminum I've been dealing with is beer can aluminum.  :)
I do have everything ready to go, I just need time. I'm going to open up the oil pump again and install new o-rings in the pump body and a shaft seal on the gear drive. It was difficult to find the parts numbers! I did manage to find a NOS rubber leak stopper plug and spring. Wish I had been able to find a NOS bypass spring but no luck. The studs aren't torqued yet but they look good sitting there. You'll probably pass me real soon. I'm headed out on the road 10/6 for about 3 weeks. Colorado to Key West via Biketoberfest.
Keep up the good work!! I think I'll always remember 15/10,000's (.0015). Seems magical.
Offline michrobi
« Reply #216 on: September 27, 2010, 11:13:45 AM »
Haha, I wasn't going to say anything but I even gave that guy the $10 for a 10x82   :D
-Mike
« Reply #217 on: September 27, 2010, 05:59:29 PM »
Yeah but what about the original 8 X 56 that we can get as 8 X 55 from Honda?! Nobody else will be as original as we are with NOS unobtainium 10 X 82 and 8 X 56! I'd like to think that $8+ of that was shipping from Thailand. So what if we're 900?!! We try harder than anyone else and it shows!!
« Reply #218 on: September 27, 2010, 10:48:55 PM »
Geez, you're really pumping yourself up Jerry, take a break mate, or you'll do yourself some damage!  ::)  ;D
Online Sam Green Racing
  • Moderator
« Reply #219 on: September 28, 2010, 01:33:25 AM »
I hate it when people talk in code :( 10/10 good buddie  ;D ;D ;D
Sam. ;) :D
Offline HedNut
  • Underwater Basket Weaving
« Reply #220 on: September 28, 2010, 04:41:37 AM »
Wish I would've got in here reading sooner! This engine is going to SPANK SOME ASS-PHALT! BoooM!  Love it!
Offline Ichiban 4
  • "Ichi"
« Reply #221 on: September 28, 2010, 06:59:07 PM »
That's a beautiful engine build you've got going there Michrobi !
Guess that's mainly something us gearheads would see..But still wanted to relate that..
Al / Ichi
Al Summers
Present: '77 550K
Offline SOHC Digger
  • I'm not an
« Reply #222 on: November 20, 2010, 08:26:41 PM »
Anything new to post?
Offline BLUE71TURBO
« Reply #223 on: November 20, 2010, 08:48:30 PM »
                                 ;D
Offline michrobi
« Reply #224 on: November 22, 2010, 12:43:40 PM »
Sorry guys, I've been distracted for a few months. I'm planning to get back on the engine build this weekend. I started the Body for Life 12 week challenge program July 5th and finished on September 26th.
Life altering.
-Mike
