Author Topic: float pins - i think i am ready to ruin a carb  (Read 3143 times)
saw750
« on: March 25, 2010, 05:29:06 PM »
so i searched the forum - checked the bible - and if i am not mistaken the only ways to get the float pins out is with a center punch/automatic sprung center punch or nail? possibly with the addition of heat?
i bought a brand spank me new heat gut today so i have the heat covered (the wife doesnt know i put it on our account at the hardware store..eh it was her birthday this week i can tell her i thought it would make a good gift) i have 6" auto. center punch
i have lubed the pillars and pin for a three days now....and i think its time to ruin the carb
is there any things else i should know before i break off a pillar? any technique? bracing etc??
sigh
Offline wireman
Re: float pins - i think i am ready to ruin a carb
« Reply #1 on: March 25, 2010, 05:44:48 PM »
take your time and don't force it mine came out easy with a little patience.
Live life to the fullest!!
75 CB 750    05 Honda 1300 VTX C
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #2 on: March 25, 2010, 05:44:55 PM »
This is a common issue.  If they are brass pins, the center punch will only make it worse by spreading the end of the pin.  A recess punch almost the same diameter is a better bet.  Support the post with a piece of steal with a slot in it, clamped in a vice and tap the punch gingerly.  If you do get them out, there are stainless steal pins out there.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
« Reply #3 on: March 25, 2010, 06:16:23 PM »
If the WORST happens (you break off a "pillar"), big-jim may be able to help ;)
Offline Hasenkopf
  • Really, I'm not an
  • This space for hire.
« Reply #4 on: March 25, 2010, 06:17:59 PM »
try using a block of wood to support the pins while you drive them out with a small drift punch....you will need to make a hole in the wood for the pin to go into,  gitting it out of the carb is the main thing...
I like berries.
« Reply #5 on: March 25, 2010, 09:36:53 PM »
I remember you had some major gumming issues etc with those. Have they had a good long soak yet in a gallon bucket of Gunk or other carb cleaner to really loosen them up other than just oil.I use a nail with a flat ground end to gently tap from both ends to get it loose.
Offline fastbroshi
  • Puppet
« Reply #6 on: March 26, 2010, 12:39:57 AM »
  Well once you get them out, it wouldn't be a bad idea to polish them with lightly with ye olde dremmel, may taper the last half mm on the ends to aid removal and insertion in the future.
Just call me Timmaaaaay!!!
Offline Johnie
« Reply #7 on: March 26, 2010, 05:34:31 AM »
So you must have already tried PB Blaster. No sense to rush it. As a last resort how about a fine drill with a block of wood as support. I would try that before I would smack that post. But give the PB a chance to work. If you think about it, both ends of the float pin are probably stuck. How about cutting that pin off so rather than working against 2 stuck ends you can work one at a time.
« Last Edit: March 26, 2010, 05:37:19 AM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Jim F
  • go baby go
« Reply #8 on: March 26, 2010, 07:25:32 PM »
Saw, If you break one just call me and I can weld that back for you.
I do it all the time so its pretty common when rebuilding an old carb
Jim French
www.jmfmicroweld.com
Here are some pictures
http://forums.sohc4.net/index.php?topic=18649.0
« Last Edit: March 26, 2010, 07:28:20 PM by big-jim »
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
saw750
« Reply #9 on: March 27, 2010, 09:22:18 AM »
thanks everyone for the suggestions and pointers..
well i managed to get one out without breaking a pillar..i bent them a lil but no breakage..
the float didnt survive nor did the pin.
and yes i was being very very very careful. this puppy wouldnt move with out brute force.
i soaked, i heated. i did everything by the book (no i didnt drill - i lack the dexterity and the equipment to do extremely fine work)
those pins are cemented in place - tired my best but again what worked was repeated heating and lubrication.
after three days of soaking - it was heat heat heat and more lubrication before it even moved just .5mm..ugh and then i just kept working it...pulling..center punching heating and lubricating
wow...
Offline Johnie
« Reply #10 on: March 27, 2010, 10:37:32 AM »
Good for you...just goes to show you can not rush these things. Now you are better equipped for the next time you do it.
Oshkosh, WI  USA
Offline fastbroshi
  • Puppet
« Reply #11 on: March 27, 2010, 12:33:55 PM »
Jim French
Wow those are pretty cool Jim, it looks like the laser just goes back and forth vs. in circles.  Still looks great though.
Offline fastbroshi
  • Puppet
« Reply #12 on: March 27, 2010, 12:35:15 PM »
Good to hear you finally got those out man, luckily I haven't run into that yet, knock on wood.
saw750
« Reply #13 on: March 27, 2010, 12:54:27 PM »
well i am not pattin' myself on the back just yet - one down and four to go
there has to be some greener alternatives to the usual solvents that actually work - lets just say i feel a lil twitchie and feel like i have been punched in the bearings..lmao
i wonder if my wifes sonic jewelry cleaner would work as parts cleaner..lmao
is it even worth trying to save the floats?
Offline fastbroshi
  • Puppet
« Reply #14 on: March 27, 2010, 01:01:04 PM »
  Judgement call on that one.  I assume the carb was secured in a vice or some other way so you weren't constantly hitting them.
saw750
« Reply #15 on: March 27, 2010, 06:13:26 PM »
yes secured and braced (obviously my bracing could be better)
Offline RatBikeRandy
  • Yes I Can
« Reply #16 on: March 28, 2010, 08:01:56 AM »
Being VERY careful, 3 came out OK.  Guess what happened on the 4th?  I was able to repair with very small pin for strength and JB Weld.  I checked up on the stuff first and it doesn't break down in gasoline.  Two years in and no problems.
« Reply #17 on: March 28, 2010, 08:17:20 AM »
Lacquer thinner works well on soaking these, too. It dissolves the varnish, and quickly.
After the pin is out, run a drill bit by hand through the pin support and spin-polish the brass shaft in a drill with some fine sandpaper. They will last for many years, again.
saw750
« Reply #18 on: March 28, 2010, 12:03:02 PM »
good tip thank you - what size drill bit??
well that second pin came out without an issue..soaked over night..a little heat and tap tap it was out.
after the last pin i have to say this was anti-climatic ...i expected a struggle like the last one but nothing..sigh lol
on this latest carb i noticed that the the brass syphon tube in the bowl was notched-ringed? is this something that needs to be replaced?
oh amal how i miss you...lmao
thank you in advance -saw
Offline Fabricator
    • crmfabrication.com
« Reply #19 on: March 28, 2010, 04:25:43 PM »
Nice work in the repair pics Jim!  I welded one for a friend with my Synchrowave 300.... That was "fun".  I was using a WP300 weldcraft liquid-cooled torch.  I like your method better   ;)
Fabricator
"When in doubt, gas it. This; to be honest, doesn't always solve the problem, but at least it ends the suspense." (Mark Gardiner from "Riding Man.")
Life is too short to dance with ugly girls.....
Offline Jim F
  • go baby go
« Reply #20 on: March 28, 2010, 05:34:30 PM »
Fabricator
Thanks
« Reply #21 on: March 29, 2010, 06:08:06 AM »
I just use a drill bit smaller than the hole, then drag it back & forth like a file to use the sharp flute edges on the insides of the holes. You're just scaping off the non-metallic corrosion that made it stick so much.
What's a "syphon tube". ?  ???
saw750
« Reply #22 on: April 07, 2010, 04:12:34 PM »
eh i was two for two - saved two, ruined two.
so what did i learn. let it soak. let it soak. let it soak.
what i found that worked the best was just letting the old carb soak in bucket of simple green for a couple days
carb cleaner, liquid wrench, pb plast etc etc - those products alone did not do the job of the eco friendly simple green (and my nads didnt hurt as much)
let it soak!!!!
once out of the soak i did oil w/pb blast and work the floats.
then added heat and the pins came out nicely
repeated applications of pb blast or liquid wrench over a couple days without the aid of soak ended with two ruined floats and pins
let it soak!! simple green. soak and walk away!
thanks everyone
Offline D
  • 1979 CM185T, 1981 cb650c
« Reply #23 on: July 16, 2010, 12:31:06 AM »
I just did a carb with stuck float pins, they seemed to be immovable. I let the carbs soak in straight simple green for over a day. Then I sprayed the carbs and pins with aerosol carb leaner. After that I put the bowls on filled with gasoline, let it set for less than an hour. Took the bowls back off sprayed pins with pb blaster, then reached for the hammer and punch. One technique I used to avoid breaking the post was to allow the entire carb to move while I hit the pin with a gently semi-pointed punch. The key is to not hit too hard and allow the carb to MOVE. After the pin broke free I used a small allen wrench to push the pin entirely out rather than grab it with any pliers that would gouge and score the pin.
Offline morethrottle
« Reply #24 on: July 16, 2010, 04:10:30 PM »
I guess I've been lucky getting them out just using a small finish nail, and it seems like they always want to come out one way easier than the other! (after a good soaking of course!!)  I was wondering what is the best way to peen the ends after reinstallation? Sometimes they go in a little too easy after cleaning. Thanks.
2005 Yamaha YZ250F (stolen)
1974 Honda CB750K4(836)
1971 Honda CB500
1971 Honda CB450
1976 Yamaha XT500C
