Author Topic: Keihin CR Carbs....  (Read 13800 times)
Keihin CR Carbs....
« on: April 25, 2005, 08:25:55 AM »
 Who here has used them (either the 29's or 31's). I'd be interested in swapping the good and bad points as well as common problems. I'll start first by saying Sudco is friggin useless. Their first response to 99% of problems is "that's the first time I've heard of that". If I had a dime for every time I've heard that from them as well as other suppliers.Christ  I don't think the old Sudco receptionist knew they sold carbs.
Re: Keihin CR Carbs....
« Reply #1 on: November 04, 2005, 08:56:30 PM »
Was telling Sean just that last week. ;D ;D ;D
caferacer550
« Reply #2 on: August 21, 2006, 11:22:42 AM »
I too was wondering if anyone could share opinons on these carbs.
Easy to install and tune?
Are they worth the money?
« Reply #3 on: August 21, 2006, 12:21:40 PM »
I do have lots of experience AND opinions on CR's. One opinion is a accelerator pump would not be a bad idea as long as it had good adjustablilty like the Mikuni RS series. The Keihin FCR accelerator pump has poor adjustability. They (the carbs alone) are worth 4 or 5 on top with port work.
caferacer550
« Reply #4 on: August 21, 2006, 03:25:26 PM »
Are they considered to be strictly race carbs.
Or can they be used for a daily rider?
Offline scondon
  • Mmmm......tasty bugs
« Reply #5 on: August 21, 2006, 04:51:10 PM »
I'll have some input in just a couple more months ;D ;D ;D
   Mike, I'm sending you some mail this Friday. You should expect it next week.
« Reply #6 on: August 21, 2006, 05:28:30 PM »
I should think you could use them on the road as Mike does, not sure about availability of filters though.
We have been useing them for 3 years now and not had to touch them, then again one dosn't clock up a lot of miles drag racing. ;D
Sam
« Reply #7 on: August 22, 2006, 06:54:23 AM »
Sam
Sam is correct....I have used them for years (29's and 31's) on the road.
78CB750F1
« Reply #8 on: August 22, 2006, 07:55:55 AM »
I am running 29mm Keihin CRs on my CB750 with stock motor and the performance is great - for daily use, I would recommend running the individual K&N filters rather than the velocity stacks that come with the CRs.
« Reply #9 on: August 22, 2006, 09:25:16 AM »
   On the sets that I have used, I usually modify the stock idle screw for a remote idle screw (usually mounted to the air box mountng flange) . The stock idle screw is on top of the carbs and hard to get to when installed.
 Daniel
  Like this..........
Offline dusterdude
« Reply #10 on: August 22, 2006, 10:52:15 AM »
how does one go about fashioning such an item like that?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
caferacer550
« Reply #11 on: August 22, 2006, 11:31:35 AM »
Where is the best place to by a set of CR's for my 550?
Or are they all selling for the same price? (M3, Sudco)
Does anyone know if there any other after market carb options for the 550 besides the CR's?
Thanks.
« Reply #12 on: August 22, 2006, 11:40:08 AM »
Mark, I made that from an old ZX10 part. The ZX10 bolt at the end didn't fit so I cut it off, drilled into the top off an Allen head bolt and soldered in the cable. I put some shrink wrap on it prior to soldering and shrunk it aroung the head of the Allen and the end of the cable. I wouldn't be surprised if the remote adjuster from a set of Keihin FCR's would work. You could just order it from Sudco then.
« Reply #13 on: August 22, 2006, 11:54:31 AM »
Thanks.
Sudco supplies all the Mikuni and Keihin carbs in the USA. Everyone has to get them from Sudco. Sudco doesn't list 26mm carbs for the 550 BUT they do for the 400F. I'd guess the spacing is the same but I'm not sure. If they will work I'd just order them from Sudco unless someone is giving a discount. There really isn't that much mark up though
« Reply #14 on: August 22, 2006, 12:02:56 PM »
I think what Mike said about the mark up is correct. I had a dealer friend request a new catalogue and check on pricing for a set of 31mm. He told me his cost was almost $600.
Offline dusterdude
« Reply #15 on: August 22, 2006, 01:23:06 PM »
cool,you`re a smart mutha. ;D
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline sparty
  • I just play one on TV
    • Gallery
« Reply #16 on: October 12, 2006, 05:12:39 AM »
 Daniel
  Like this..........
Mike,
Can you, when you find the time, send me a list of parts that I would need to make a remote idle screw for my CR carbs and some detailed instructions on how to do it?
Thanks,
Sparty
1972 CB750 K2 Cafe' Style
Offline aptech77
« Reply #17 on: October 12, 2006, 08:30:55 PM »
I'm running 31MM CVR on my 400F. Easy to work on, No problems, BAD ASS!!!!   ;D
« Last Edit: March 02, 2007, 04:12:32 PM by aptech77 »
Offline Hockers Choppers
  • go away winter!!!
« Reply #18 on: December 01, 2006, 06:21:04 PM »
anyone running the mikuni smooth bore carbs? can find them on ebay all the time but can't find any cr's and don't have $700 to spend. need them for a 750 with cam, porting and 836.
The thing about common sense is that, it's not that common.
1978 CB750F SUPERSPORT 850cc, cam, porting, dyna ign, cr29's lotsa elbow grease and $$'s. Worth ever penny!!  (S0ld)
05 VTX1800F darkside
cb750 k1
Offline heffay
« Reply #19 on: December 01, 2006, 09:23:30 PM »
ok... trying not to sound like a moron... is my terminology correct?
CR: constant ratio
CV: constant velocity
Offline crazypj
  • I'm brill, me
« Reply #20 on: December 01, 2006, 11:56:11 PM »
First time I saw the insides of them I thought 'hey, AMALS done modern' ;D As long as you dont go too big they make excellent street carbs. They flow much better than standard round slide so you use a smaller size which gives better carburation everywhere.
I put a set on a CB 350 a while back,(modified from a Z 900 rack) must be good as I haven't seen the guy since (you know he would be back to complain if it wasn't right)
The Mikuni's are very similar( they were originally AMAL made under license) and Sudco seems to have a lot more experience with them (and parts seem to be easier to get)
BTW, if you need odd sized taps and dies,(5x0.5mm for example) Victor Machinery Exchange in New York is the best place I've found in all the US and was a lot cheaper than getting stuff from Europe, (particularly the way the dollar has tanked recently)
PJ
« Last Edit: December 02, 2006, 12:03:23 AM by crazypj »
Offline crazypj
  • I'm brill, me
« Reply #21 on: December 02, 2006, 12:13:24 AM »
CR: constant ratio
NOPE, CV is vacuum operated, you can put huge carbs on and engine only takes what it wants. CR have a block inside the slide (which is either linkage or direct cable operated, although I don't think thy were originally designed for direct cable operation, I make new tops and slide mods). the slide walls are very thin so don't disrupt airflow. It looks like an inverted tube with a cap on one end where linkage ( or cable) connects
Heres a picture of a Mikuni smooth bore, through the carb bore. the slide rides in the narrow slot
PJ
« Last Edit: December 02, 2006, 12:18:06 AM by crazypj »
Offline Geeto67
  • A grumpy
« Reply #22 on: December 02, 2006, 06:17:18 AM »
CR: constant ratio
PJ
CV does stand for "constant velocity". They are vacuum operated carbs where by the draw of engine vacuum lifts the slide instead of a cable, and the engine takes what it needs. They are called constant velocity because the carbs work by balancing vacuum of the engine (below the slide) and the the vacuum above the slide.  (right on the description, wrong on the name crazypj):
"When you twist the throttle, this lifts the slide and immediately increases the size of the carburetor opening letting in more air/fuel mix and increasing the speed of the motor.  On CV carburetors, the throttle cable actuates a butterfly valve and, as the throttle is opened, the air pressure difference between the sealed chamber above the vacuum slide and inside the carburetor venturi forces the slide (located in front of the butterfly valve) up and down.  The downside to the CV carb is a lack of immediate throttle response. Twisting the throttle gives relatively leisurely acceleration compared to a conventional carburetor. One of the advantages is that the carburetor adapts nicely to altitude changes and good gas mileage ."
http://www3.telus.net/dougsimpson/CVcarb.html
This place seems to list both SOHC and DOHC cb750 CR carbs. I've NEVER dealt with them so cavet emptor:
http://www.cyclewareables.com/pages/keihin_cr_parts/keihin_cr_four_cylinder.htm
I always thought the CR was just a carb series or model number (like mukuni VM) - I too would like to know if it stands for constant ratio?
« Last Edit: December 02, 2006, 06:19:01 AM by Geeto67 »
Maintenance Matters Most
  • go away winter!!!
« Reply #23 on: December 02, 2006, 06:47:29 AM »
I think CR stands for competition racing.
cb750 k1
Offline aptech77
« Reply #24 on: December 02, 2006, 06:53:25 AM »
You are right on with the your info....except....."The downside to the CV carb is a lack of immediate throttle response. Twisting the throttle gives relatively leisurely acceleration compared to a conventional carburetor"....Not so true....there are ways to take care of this and the operation of CV carb is MORE responsive and smoother run with a more balanced flow. My launches like you were on the shuttle.
