Author Topic: Wandering idle ('74 CB550)  (Read 991 times)
klindsey
« on: March 26, 2010, 12:49:19 PM »
Greetings.
Just finished rebuilding my '74 CB550.  Runs great (although it's a bit underpowered).  Issue is this: after it's warmed up and we're sitting at a traffic light, the idle will wander back and forth between about 1200 and up to 2000.  Sometimes it'll just stick at 2000.  When we get back in gear, the bike's great.
I haven't synched the carbs yet, although I did a valve job a couple of nights ago.  Would out-of-synch carbs cause this?  What else might be a culprit?
Many thanks,
Kevin
Offline Really?
Re: Wandering idle ('74 CB550)
« Reply #1 on: March 26, 2010, 12:58:49 PM »
Out os sync carbs might, depending on how far they are out.  You may just have a vacuum leak somewhere.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #2 on: March 26, 2010, 01:05:20 PM »
+1.
Offline Inigo Montoya
« Reply #3 on: March 26, 2010, 01:06:25 PM »
Spray some carb cleaner around the boots and see if idle changes. Quick check often suggested here.
klindsey
« Reply #4 on: March 26, 2010, 04:44:10 PM »
Good point.  Shudda thought of that first.  I'll do the WD40 thing around the boots and see what gives.
