Author Topic: side play in exhaust valve guides okay?  (Read 3424 times)
Julien
« on: March 26, 2010, 07:09:16 PM »
I found some side play in my exhaust valve guides, is there an acceptable amount of valve to valve guide movement?
« Last Edit: March 26, 2010, 07:11:14 PM by Julien »
Re: side play in exhaust valve guides okay?
« Reply #1 on: March 26, 2010, 07:21:01 PM »
Lift the valve 0.250" off the seat, measure side-to-side looseness at that lift. Honda says 0.0032" is the max allowed. Usually if they are more than 0.0060" they will cause exhaust gas blowby into the head, polluting the oil in a few hundred miles of run time. Installing new seals will help reduce that problem for a season or so, but new guides are a better bet.
If the valves get more loose than about 0.005" side-to-side, they close slowly and limit the RPM before the piston hits them for being in the way too long.  :o
Offline Jim F
  • go baby go
« Reply #2 on: March 26, 2010, 07:22:03 PM »
Check your manual as its only a a couple of thousands per side
If you have access to gauge pins you can check the ID of the guides to the OD
of the valves and go from there.
Good luck
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
« Reply #3 on: March 26, 2010, 11:55:45 PM »
WHAT BIKE
Offline fire113
« Reply #4 on: March 27, 2010, 06:19:11 AM »
...change the valve guides!
I have to do the same thing :(
EDIT--> You can remove one of the intake valves and put it into the exhaust valve guide to be sure that it isn't the valve shaft.
« Last Edit: March 27, 2010, 07:42:03 AM by fire113 »
