Author Topic: No spark from coil cb 750  (Read 1698 times)
Offline paddy paul
« on: March 27, 2010, 10:13:42 AM »
I have power to the coils, to the points, good spark from the points but nothing at the spark plugs, Starting to get a frustrated, I'm missing something swapped out the coils same thingany suggestions... Thanks
Re: No spark from coil cb 750
« Reply #1 on: March 27, 2010, 10:23:33 AM »
HMM. Where do the kill switch wires tie into to all this  ??? Did it or has it ran correctly in recent history ?.
« Last Edit: March 27, 2010, 08:11:00 PM by ekpent »
Offline 1080
« Reply #2 on: March 27, 2010, 08:04:40 PM »
Bad sparkplug?
Offline paddy paul
« Reply #3 on: March 28, 2010, 03:24:22 PM »
new spark plugs used for the testing, they checked good, just bought the bike, been sitting outside for 6 years, the off/on switch, I believe kills power to the points, but I have power coming out of the points to the coils, need to check the coils I guess to see if they are good
Offline GammaFlat
« Reply #4 on: March 28, 2010, 03:33:46 PM »
how about your plug caps?  NGK makes real nice ones for a few bucks apiece.  You might also check to see if your plug caps are screwed in well.  I understand the end of the wire can get mucked up so "dressing up" the end of the wire is sometimes necessary.  Unscrew the plug cap, cut 1/4" off the end of the wire, then screw in the cap again.
K6
85 Goldwing
