Author Topic: Pulling Stator  (Read 1376 times)
Offline jtb
  • An unlikely
Pulling Stator
« on: January 20, 2006, 07:02:02 AM »
What is the best way to keep the crankshaft from turning while removing the stator bolt?  I put a long handled wrench on the points side, but it just picks up that side of the engine when I try to turn the stator bolt.  All suggestions and experience will be appreciated.
John
1977 CB750F
1985 V65 Sabre
Offline Raul CB750K1
Re: Pulling Stator
« Reply #1 on: January 20, 2006, 07:30:25 AM »
You can buy a clutch cage tool to make the clutch static while you turn the bolt. Of course, if the engine is still on the bike engage a high gear and you are good to go. IF the cylinders are out, put some pieces of wood over the crankshaft and put a thick piece of metal on the connecting rod, thus avoiding it to "sink" into the crankcase.
I was going to replace the camchain, so I just let the crankshaft swalow it until it got jammed and then I was able to remove the bolt.
Raul
Offline cadler
Re: Pulling Stator
« Reply #2 on: January 20, 2006, 07:34:02 AM »
do not put a wrench on the points side bolt, that will brake easily.
I used WD-40,a stap wrench, and the tranny in high gear and got it free
kaysystems
Re: Pulling Stator
« Reply #3 on: January 20, 2006, 05:43:20 PM »
Does the rotor have to come off? Or can the cases be split with it on the end of the crank?
I assume there is no oil seal there that needs changing.
David
Re: Pulling Stator
« Reply #4 on: January 20, 2006, 05:56:00 PM »
The rotor doesn't need to come off to split the cases and remove the crank, I think John just wants to take it off, he knows that the alternator is oil bathed and there's no crank seal on that side.
Just get a big screwdriver and poke it through the rotor, then pushing on that, and pulling on the wrench, you'll be able to undo the bolt, without harming anything. Then enjoy yourself getting the rotor off John, if the Honda special tool won't budge it (It had no effect on mine except to tear out the threads) a good 4 jaw puller is invaluable! Cheers, Terry. ;D
Offline jtb
  • An unlikely
Re: Pulling Stator
« Reply #5 on: January 20, 2006, 06:56:52 PM »
Well, thanks, everyone.  Terry I got out the GBMFSD (great big yada-yada screw driver) and did exactly as you suggested, and as I pushed down hard on my  3/8" drive big wrench, with the cheap 19mm socket, I heard that familiar click you get when a bolt comes loose.  Then the wrench fell off, and my wonderful 19mm cheap socket was no more.  This prompted a trip to Sears for a 1/2" drive 19MM 6-point socket, plus a 17MM 6-point for good measure, and as long as I was already there, a set of 6-point 3/8" drive sockets.  After this, a quick application of the GBMFSD and the 1/2" drive on a long break over handle quickly dispatched the bolt.  Now you guys tell me I don't need to remove the stator to split the cases, I think I'll just torque it back on.  Any way, do I need any special tools to split the cases?  I have already purchased the necessary amount of beer. (chuckle, chuckle)  ;D ;D
1977 CB750F
1985 V65 Sabre
Re: Pulling Stator
« Reply #6 on: January 20, 2006, 10:09:09 PM »
Dintcha read my reply to your email mate? Geez I slaved over that bloody keyboard to tell you that you don't need to remove the rotor? Oh well, you're not the only one to ignore me, boo hoo! :'(
Offline jtb
  • An unlikely
Re: Pulling Stator
« Reply #7 on: January 21, 2006, 05:40:14 AM »
Geez, yourself, Terry.  How are you?  I didn't get your email.  My hosting service put in a new anti-spam program, and suddenly I'm not receiving replies to a lot of emails.  I sure wish I had received it. :( :(
John
1977 CB750F
1985 V65 Sabre
Offline JonnyHonda
  • I've been ill, ok.
    • Honda-SOHC
Re: Pulling Stator
« Reply #8 on: January 21, 2006, 11:27:11 AM »
I've split my crankcases twice and both times tried to take the fly wheel thing off. Failed both times. Getting the bolt out is the easy bit unless you have the honda puller.
On email, my company uses antispam as well, and I don't half the work sent to me I used to  ;D ;D
Regards and Ride Safe
<url>http://www.honda-sohc.co.uk</url>
Re: Pulling Stator
« Reply #9 on: January 21, 2006, 02:43:16 PM »
John
Fair one John, probably my fault too, I've had a few emails returned, do you think I should change my email address from sonofspam@yahoo.com to something less threatening?
I only used that email address at the request of my neighbours black lab, and then he told me I'd f*cked up anyway? Damn dog won't shut up! Oh well, i'm off to clean my .44 and go for a drive..................  ;D
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
Re: Pulling Stator
« Reply #10 on: January 21, 2006, 03:10:02 PM »
The dog? won't blacky get a little green? ;D
James
And so I'm on topic.  I split my case and left that great big hunk of copper on the end. ;D  Now to get the spares I need to put everything back together.
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
Re: Pulling Stator
« Reply #11 on: January 21, 2006, 03:16:25 PM »
James
Ixnay, on the ackyblay, okay? >:(
