Author Topic: Bearing color Help  (Read 1230 times)
Offline MattFreeman
  • What Have I Done?
Bearing color Help
« on: March 27, 2010, 05:41:00 PM »
When ordering bearings do you match part #'s together for each journal?
For example I found that there two different "A black" crank/case bearings, one is 208332-001 and the other is 208333-001. The A black ones seem to be the only one with this in question. The others only list one # per letter/color code.
With the con rod bearings there is only one # for the B black but two choices for the other codes.
Can anyone shed some light on this please? I'm trying to purchase a couple bearings so I can plastiguage and start the fitting/rebuild process for my '76 CB750 SS.
Offline City Boy
Re: Bearing color Help
« Reply #1 on: March 27, 2010, 10:15:27 PM »
Hi Matt.I have looked at the shop and parts manual.I can't find any bearing #'s like what you have listed.For instance,black main bearing is 13315-300-013 and black rod bearing is 13215-300-013.Also,only one part # is shown for any colour,rod or main.   Rock On
'52 Kiekhaefer Mercury Rocket Hurricane KG4H
'70 750/RC 1000 Original Owner
'83 1100F
Offline MattFreeman
  • What Have I Done?
« Reply #2 on: March 28, 2010, 06:44:07 AM »
I'm finding this on BikeBandit. ??? ???
Offline wrenchmuch
« Reply #3 on: March 28, 2010, 07:23:36 AM »
When I did my motor I had both kinds come from bike bandit . One was a satin finish on the bearing surface and the other was polished . I believe that the tolerance will be the same for both . I think its just a matter of parts being superseded over time . I have both in my motor with no trouble .
Mike
CB750K1
CB750K4
Offline City Boy
« Reply #4 on: March 28, 2010, 08:15:15 AM »
Hi Matt.Sorry bout my confusion.I would say as long as both halves of bearing shells are same colour in Bike Bandit, dimensions should be same and compatable with each other.    Rock On
'83 1100F
Offline MattFreeman
  • What Have I Done?
« Reply #5 on: March 28, 2010, 08:18:05 AM »
Thanks guys.
Wrench I'm glad to hear your experience was good. :) :)
Thanks again.
Offline MattFreeman
  • What Have I Done?
« Reply #6 on: March 28, 2010, 08:19:52 AM »
I'm sorry for the confusion, I didn't give enough info. :-[ :-[
Offline wrenchmuch
« Reply #7 on: March 28, 2010, 10:10:06 AM »
Just make sure that on any one journal you have like pieces with the same part number .
CB750K1
CB750K4
