Author Topic: K0 final drive bearings  (Read 1263 times)
Offline AshimotoK0
  • CB400/4, 69 CB750K0, '69 CB250SS, CB350K1 CB500K0
« on: March 28, 2010, 07:22:16 AM »
Hi,
The final drive bearings on my '69 750 K0 are the NR 'grooved' type (with retaining ring half circular holders) but I just bought a very low mileage 1970 transmission and the these bearings on it's output shaft bearings are not grooved. Did the K1 have non- grooved bearings ('NICK' as Yamiya call them). If so how were the the bearings prevented from moving sideways in the housings? The bearings concerned are 6305NR and 6205NR
http://www.yamiya750e.com/index.php?main_page=product_info&cPath=21_53&products_id=111
http://www.yamiya750e.com/index.php?main_page=product_info&cPath=21_53&products_id=109
I think the correct Honda 6305NR bearing is 91003-259-000 which is also used on the Honda CB72 'Hawk'
and the 6205NR is 91002-300-008
Cheers !!  AshD
« Last Edit: March 28, 2010, 07:27:38 AM by AshimotoK0 »
“Alright friends, you have seen the heavy groups, now you will see morning maniac music. Believe me, yeah. It’s a new dawn.”
Offline mystic_1
  • 1970 CB750K
Re: K0 final drive bearings
« Reply #1 on: March 28, 2010, 08:26:17 AM »
Yup, K1 had a non-grooved, single-row output shaft bearing.  The retainer is a full circle that sits outboard of the bearing.  The bearing cannot move inward because it's stopped by the shaft's shoulder.
I'll see if I have any pics.
mystic_1
- John Augustus Shedd
Offline AshimotoK0
« Reply #2 on: March 28, 2010, 09:11:08 AM »
Thanks Mystic,
I guess this Service Bulletin explains the change
http://data.sohc4.net/SB750/750_29.pdf
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: March 28, 2010, 09:27:24 AM »
Yup!  That pretty much covers it.
You can run any of the bearings on the later crankcase design, but the early crankcase will only accept the grooved bearing because of the change to the keeper.
Pics below show the last three variations on the shafts from the chart on the first page.  Case is a "K1-style" numberless replacement case.  Also shown is the K1-and-later-style keeper.
mystic_1
Offline AshimotoK0
« Reply #4 on: March 28, 2010, 10:19:31 AM »
Wow Mystic that's great. I wanted to keep all of the meshing gears on the replacement transmission. Can I use the gear from the K1 final drive on the K0 shaft?
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: March 28, 2010, 11:20:37 AM »
Yes!  All variations used the same gear 23511-300-020 :)
mystic_1
