Author Topic: CB750F carb removal  (Read 1350 times)
Offline jmcgill
CB750F carb removal
« on: March 28, 2010, 07:26:28 AM »
Is there any special technique for removing the carburetors on a CB750F?  I can hardly get them to budge and certainly cannot get them out.  I was looking at the FAQ, but only found something for the 550.
I took the airbox out already and have loosened everything, but still it won't move.
Thanks for any help!
Offline Johnie
Re: CB750F carb removal
« Reply #1 on: March 28, 2010, 07:29:26 AM »
I take it you are having trouble getting them off the rubber intake boots?
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #2 on: March 28, 2010, 07:46:46 AM »
Just took some off a 71 750 project and heat is your best friend. I carefully warmed them well with a heat gun,rubber became more supple and rocking up and down with gloves  ;) they popped right off.
Offline jmcgill
« Reply #3 on: March 28, 2010, 08:17:16 AM »
I got them off....guess I was just not using enough "elbow grease"....
I hate the smell of varnished gasoline. :-X
Offline david 750f
  • 1976 CB750F
« Reply #4 on: March 28, 2010, 09:19:50 AM »
The intake manifold rubbers are still available from Honda. New soft rubbers make removal so much easier ;) ;)
1976 CB 750F
« Reply #5 on: March 28, 2010, 12:21:28 PM »
Silicone spray and hot air. I silicone grease them before putting them back on. helps seal and lube the rubber. Look up the wintergreen oil thread.
