Author Topic: can you substitue intake bands?  (Read 1053 times)
Offline kopptl
« on: March 28, 2010, 04:14:53 PM »
cb750: had to drill out a couple stripped out bands on my carb booots. could i use like hose clamps or anything else??
Offline dusterdude
Re: can you substitue intake bands?
« Reply #1 on: March 28, 2010, 04:22:07 PM »
i dont see why not
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #2 on: March 28, 2010, 04:52:19 PM »
As long as they are not too wide to fit the groove, hose clamps should be stronger than the wimpy Honda ones. Let us know it you find anything standard size.
Offline Fabricator
    • crmfabrication.com
« Reply #3 on: March 28, 2010, 05:33:00 PM »
I have used some from Mc Master Carr with excellent success.  I do not have access to the box to get the part numbers, but I got the stainless steel version, and they were 10 to a box, and about $20 for the lot.  Measure your band width, and the diameter of the clamp area on the boot.  You will need that information to select the correct ones on their website.  They fit perfect!
Fabricator
"When in doubt, gas it. This; to be honest, doesn't always solve the problem, but at least it ends the suspense." (Mark Gardiner from "Riding Man.")
Life is too short to dance with ugly girls.....
Offline kopptl
« Reply #4 on: March 30, 2010, 10:15:06 AM »
well i have foiund atleast one replacement clamp for my intake, and it was at a local outdoor service shop and they clamp is actually for a seadoo jetski!!!!! should work fine! if onyl they had 3 more!!!
Offline Superior Chops
« Reply #5 on: March 30, 2010, 10:37:18 AM »
Google Norma clamps. I believe the product name is Torro. I've used them in the past. They have a rolled edge and fit the original groove exactly and will not cut the boots like garden hose clamps. I don't recall the exact part number but they do work well.
Offline Whaleman
« Reply #6 on: March 30, 2010, 10:54:30 AM »
I bought some from Carpy that are high quality. Dan
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #7 on: March 30, 2010, 11:16:25 AM »
if you pay for shipping i have a couple that you can have
Mark Twain - Notebook, 1894
« Reply #8 on: March 30, 2010, 11:29:38 AM »
Anyone using hex-topped screws for holding the clamps in place? Would be better then the philips-head screws no?
Offline lone*X
« Reply #9 on: March 30, 2010, 11:47:54 AM »
Several years back I had to replace a couple of clamps due to being stripped.  To keep things looking correct I moved two good clamps to the outside and secured the two inner boots with hd quick release zip ties.  Chinched down tight they don't leak, don't cut, and with a press of a tab, can be removed by hand.  Just choose a size and color appropriate to the task.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
