Author Topic: Split - What is wrong with the stock Honda induction system?  (Read 26213 times)
« on: March 17, 2010, 07:04:41 PM »
Lloyd,
Nice work debunking K&N's claims. With reference to this picture, what goes on the hose nipple just above the number 5? Is it the same drain hose that was fitted to the CB500 air chamber?
That part number shows up in the CB550 air cleaner fiche. If so, how is it supposed to be routed. Thanks.
It is a reduced diameter tube and it routes down to behind engine and in front of the swing arm.
It is NOT the same as the one fitted to the bottom of the filter chamber.  That one has a cap on the end with a slit so when pinched water can be drained.
Offline NickC
« Reply #1 on: March 17, 2010, 07:05:54 PM »
What's wrong with people that like the way pods look?  ???
Actually, I have wondered that very same thing.  But, I don't ever expect to get a real answer.
It baffles me why people would replace good engineering for a badly engineered product.
How about good ole personal preferance?
If the person is aware of the problems that may arise when switching to pods, willing to take the steps necessary to correct said problems to the best of their ability, and happy with the end result regardless of how "perfect" it runs, why speak down to them as inferiors?
Offline BLUE71TURBO
« Reply #2 on: March 17, 2010, 07:12:47 PM »
Just throw a turbocharger on it and you don't have to worry about any of this !!!   ::)  ;D
« Reply #3 on: March 17, 2010, 07:22:49 PM »
Now, if they #$%* and moan because they don't want to spend the time tuning to compensate for the changes, yes.
TT isn't talking about how they look rather, how they work or don't work...
I completely understand, but it's obvious of TTs disdain for people running pods. Don't get me wrong, I'm running the stock induction system, and it works awesome for me, I'm just saying it's pretty obvious at what he's shooting at.
I think you are reading far more into it than what was posted.  Misdirecting the intent of a thread.  And, you are completely unfamiliar with how engineers work.
There is no emotion, no aesthetics, it works well or it doesn't from an objective stand point.  Some designs work better than others and there are reasons for that.  If you wish to be blissfully unaware, that is your choice to make.
I am still baffled why someone insists on replacing well engineered product with shody (or no) engineered product.
I was asked by a member my thoughts/knowledge on induction design.  And, now you are complaining that I responded with an objective analysis.
I know I can't please everyone.  But, really?  Are you suggesting I should post nothing at all that you don't personally approve of?
If you don't like my information, please then don't read it.
« Reply #4 on: March 17, 2010, 07:25:39 PM »
Nice job putting that together TT!!  But what I really would like to see is some dyno sheets.  Well maintained stocker with a stock airbox against dialed-in pods on the same bike.  Timeslips from the drags have too many variables thrown in, but its hard to argue with a dyno sheet.
Thanks.
Are you willing to fund what you'd like to see?
« Reply #5 on: March 17, 2010, 07:31:27 PM »
Personal preference has little to do with engineering or how a device works.   The purpose of the thread was to allow people to be aware.
If you have nothing technical to add beside personal grumbling about some ill perceived wrong, please start a new discussion thread in the open forum.
Offline NickC
« Reply #6 on: March 17, 2010, 07:52:40 PM »
Don't get me wrong, I appreciate the info. You're holier-than-thou mentality tends to irk me from time to time  :D
I just foresee this thread being copy and pasted into every thread when someone asks how to best tune for their pods, along with some comment on how the Honda would be rolling in their graves, had they not risen from them  :D
« Reply #7 on: March 17, 2010, 08:12:07 PM »
Well you certainly went to a lot of work..
Its not convincing me for a few reasons..
 Its theory, and theory works well on paper, and should work well on the bikes.
 However in the real world, it us not always so..
 What look like it should work does not alway & what looks like it should not work, sometimes does..
Back to your thread title (dont ask me to start a new thread, I am addressing what you asked)
 Its cumbersome and a pita to work around.. Like baggers & wings, it is just more stuff than I personally care to re & re to work on my bike ( other may also share that opinion)
 There is a lack of accelerator pumps on the carburation on most CB 750s, when they did finally try to address this they came up with a puny system that did help.
 In my personal experience, the aircleaners I changed to seemed to help performance, certainly got quicker with the changes, not slower... reached my goal and expectations.
 In my experience fuel mileage suffered with the stock box.
 The stock carbs have limitations, I chose to use other carbs that have far greater tuneability, and are FAR easier to change jetting.
 This last section I posted directly addresses the thread title.
 A word about K & N's, They are still using the same basic design  or fitration media that they did 35 yrs ago.. it appears their basic product could be working as they did not see fit to make radical changes to it.
 Does Honda still use these  (described on here) induction designs from the 70's..?.. or have things evolved..?
Offline Gordon
  • 750K1, 550K2
« Reply #8 on: March 17, 2010, 08:18:16 PM »
....Or, why didn't they use POD filters like all the really cool racers have on them.
If you had just left it at "Or, why didn't they use pod filters", you probably wouldn't have ruffled any feathers, but then I'm sure you knew that.
Offline Hasenkopf
  • Really, I'm not an
  • This space for hire.
« Reply #9 on: March 17, 2010, 08:32:20 PM »
finally a technical explaination that even the th huddled masses can understand, thank you !!
I like berries.
Offline sangyo soichiro
  • Tuck
  • ☢ the atomic playboy ☠
« Reply #10 on: March 17, 2010, 08:33:28 PM »
I think what Lloyd is trying to get at is that when people add pods naively thinking they're enhancing the performance, they may actually be doing the opposite.  And some people do actually think that by just adding pods they are increasing their horsepower.
I see it here all the time (and may be a victim of it myself...).  People buy their bike and the first thing they do is yank the stock box off and ask what jet size they need for their pods.  Or worse yet, they ask about drilling the jets.  And the worst is when they type the word pods as PODS - as if for some reason they are so great that they deserve all caps.
I'm sorry, but when I see these posts I get the feeling they have no idea what they're doing.  And that's fine... we all have to start somewhere.  But I can understand how the old timers like Lloyd have to roll their eyes when they see these posts over and over and over again.
1974 CB 750
1971 CL 350 Scrambler
1966 Black Bomber
Too many others to name…
bmarshall
« Reply #11 on: March 17, 2010, 08:37:50 PM »
TwoTired,
Thanks for the extensive work, you have validated what I have always known but always had a diffucult time explaining to others, I agree the stock intake is a great design, but will also agree (for the 'other side') that all designs are targeted at a certain end result and therefore will be a compromise of some sort overall (EPA mileage, emissions, noise, cost, ease of production, RPM and Power characteristics etc...).
K&N is more marketing than actual product performance, I have a Miata and those folks on the forum are ANAL! They make TT look like a high school shop student. I have seen extensive tests compairing K&N to various other filters and never have they performed well (as in filtering capability), most air filters will flow more air that your vehicle needs anyway.
Filter Pods - I also have a RD400 2 stroke, when going from a stock airbox (which once again is quite good) to pods, a huge flat spot is created around 5000 rpm, why? The air passes through the carb (1), the reed valve closes and the intake charge bounces back thru the carbs (2 - getting 'carbureted' a 2nd time and getting richer) then bounces against the flat wall of the pod and gets re-carbureted for a 3rd time, very rich by this time. Now a 4 stroke and pods may be different, but the theory may still make sound sense. By not having a wall to bounce against, any air that gets returned to the airbox is free to mix with the current air and flow into another intake track.
On 2 strokes we also run a crossover tube on the intake manifold, this way as one cylinder's intake is bouncing back (positive pressure), the other cylinder is 'sucking' from this crossover tube (vacuum) and eliminates re-carbuterating, and also in some small fashion may help force additional intake charge into the cylinder. In a sense 'tuning' the intake charge, similar to the way a header or expansion chamber helps scavange a cylinder.
TT please share your thoughts.
« Last Edit: March 17, 2010, 08:41:11 PM by bmarshall »
« Reply #12 on: March 17, 2010, 08:39:54 PM »
Oh another thing wrong with stock induction, air cleaners dont last long, other types last decades..
 I appreciate the effort you have made to explain your preferences, but I think  I will stick to what I, like.. apparently its good enough for some OEM manufacturers as well.
« Reply #13 on: March 17, 2010, 09:58:58 PM »
My .02 cents.
On drag cars with scoops, the K&N type filter has been shown to work well often better than no filter, and in a scoop can reduce the turbulence creating a more laminar flow. The old velocity stack that appears to be a good way to induce laminar flow auctually does not work as well as once thought. This may be due to the air bleeds on the top of the typical holley type carb, the ram effect upsets float level and changes the pressure exerted on air bleeds. interestingly the filter top that replaces the flat metal top on air cleaners sometimes reduces horsepower by disturbing the flow inside the filter housing. The carbs prefer the air to flow from the sides rather than straight down into the opening.
 Not sure how this relates to our hondas but there are many elements to consider.
 It was accepted that the stock honda air box tube was the best velocity stack available in the day.
« Reply #14 on: March 17, 2010, 10:40:16 PM »
That statement is a little to vague to be relevant, Other types won't last as long without added maintenance either and can do damage to an engine if not cleaned regularly, they are also effected by rain , moisture and humidity more readily than the stock filter and are more exposed to dirt and grime. We all know you like pods 754 but your information is not as correct as TT's and could be construed as misleading at times......lets stick to the facts.......Also , if pods require re jetting {larger jets}  i don't think you will get better mileage on average to the standard setup.....bigger jets means more fuel....
Offline Really?
« Reply #15 on: March 17, 2010, 10:43:07 PM »
Sounds like an early rendition of the YICS or what turned into the YICS.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline coyotecowboy
  • Easily Distracted
    • American Legion Riders Post 69 Medicine Lodge, Ks
« Reply #16 on: March 17, 2010, 10:52:31 PM »
Thanks.
Typical engineer.  Can't even take a middle of the road position with them.   ::)
The adventure begins when things stop going as planned - Glen Heggstad
http://www.alrpost69.com/
Sunrise Orange 750 K2
1981 Husqvarna 430 XC, "Inga"
« Reply #17 on: March 17, 2010, 10:57:46 PM »
Actually retro, until Aug last year I had not run ANY aircleaners for quite a while, & I have not owned pods for a long time.
 I would like to tun aircleaners on my next motor, if it is a fresh one, but I have few options with the carbs I run, other than K&N,, that is after I build the bodies...
« Reply #18 on: March 17, 2010, 11:15:32 PM »
Thanks.
Actually, I'd like to see what you are asking for as well.  I just don't have the resources to provide it, sorry.
By the way, you CAN argue with a dyno sheet, if they are from two different dynos.  They have to be calibrated.  And, some just work differently from others.
Sorry, if I lumped your response in amongst other attacks and it was unwarranted.
Offline B.O.X.N.I.F.E.
  • The Stumped
« Reply #19 on: March 17, 2010, 11:44:55 PM »
TT, very thorough. A well sorted collection of all the things you've been saying about pods on the forum for as long as I've been here. I can read between the lines and see your frustration at dealing the 'pod people'. Sometimes people just wont listen. But do understand that a select few have heard and understood the message. I certainly have. And if I were going to build a full blown cafe style bike I would put pods on it. Taking a hard line, on either side, doesn't fully take into consideration both form and function. After all, motorcycles aren't just for transportation. I submit the following:
1974 CB550
Forever West
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #20 on: March 17, 2010, 11:57:01 PM »
I have read the entire thread, and this last comment quote above sums up my take on this issue.
TT   "I" - "We" owe you a great deal of respect for your knowledge and willingness to share it with us. Even when it must get old trying to help every guy/gal here. My wiring issues alone over the past 5 years helped along by your posts were invaluable.
I think with a new title, and a slight edit.......this could go in FAQ. It's good information.
Sighned
pod owner
Offline manjisann
« Reply #21 on: March 18, 2010, 12:16:04 AM »
For anyone who thinks TT was trying to step on the Pod people (hahah, wasn't that a movie??) let me try and set the record straight. I had PM'd him to ask him for some technical info regarding how the stock airboxes worked as opposed to pods. I (foolishly perhaps) chose to mate some 73 750 carbs to my 80 650, and the intake diameters and lengths of the carbs were not the same and were causing me some issues in trying to use the stock airbox system. I was trying to determine if attempting to desing a different airbox system was worth it to me, and thus I sought his advice. Other than pointing out that the stock system was the best (insert "in his opinion" if you don't think his info is correct, however my limited experience is he knows what he's talking about) he proceded to take the time to gather this information. I again just want to thank him, and all the others here who have forgotten more about these old bikes than I will ever know, for their willingness to continue to explain stuff to us.
Again, my thanks,
Brandon
1980 CB650 Custom
« Reply #22 on: March 18, 2010, 12:45:29 AM »
Yes, three days worth.  But, I'm still willing to compare notes and data you may have.
And Honda sold how many bikes with theory forged into working product?
When first sold they were among the fastest production bikes on the planet.  Were you unconvinced back then, too?
Besides, far more engineering work has taken theory to functional product than has failed.  The odds are solidly in the engineer's favor.  Who doesn't see the technological advances today that were only theories beforehand?  The list is staggering.  And that's just the products you are aware of.
You don't have to work around it.  It works fine as it is.
You want hard to work on, try working on a performance airplane!
Prior to the EPA carbs, accel pumps weren't necessary with the stock induction.
Are you damning their carbs because your changes made them work worse in your new application?
Thanks for adding something quantifiable/measurable to the discussion.  Oh wait...I do research and present findings you clearly don't like.  And you counter with conjecture and opinion.  Pardon me if seem...perplexed.  But, in the end, there really aren't any points to argue your statement, are there?
I've recently been told by a forum member that to make the bike faster the fuel mileage must get worse.   With the added implication that poor mileage was proof of increased performance.  Interesting that this was from an adamant POD filter proponent (no brand or type specified, naturally).
No, of course I didn't believe it.  As there was no data or science to encourage such belief.  Regardless, I have no complaints about the fuel mileage of my stockers.  Perhaps the 550 induction system is better than the 750's for some reason.  Next time I take it off, I'll take some internal pictures.  But, at the time these bike were first sold, I don't believe fuel mileage was a major point in the sales of SOHC4.  Mileage and speed were kind of contrary features of the day.  Still is today.  But, adaptive systems and complexity narrow the balance.  However, for comparison, would you say the SR-71 is an inferior machine because it got bad fuel economy?  Of course, I'm not saying that any theory was put into practical use for that project.  It's just an assemblage of parts they had laying around, really.
Why would you need to change jetting in the carbs if the induction is stock?
It seems you are blaming the stock air box because it no longer functioned well with modifications you made to the bike.  And instead of changing the stock air box in concert with those changes, you tossed the entire induction, and made something else up in it's place.  I have no idea how much engineering you put into it.  Or, if you just kept trying and tweaking parts until you decided to live with the outcome.
None of us here can tell if the changes you made were actual improvements or not, as there is no data on the changes to show there was improvement or detriment.
Whatever it was, you seem happy with the result and that is what is important to you.  However, it does not have a mass market ability, or any performance numbers upon which to compare to anything else.  Sitting here, maybe I assume your performance actually did improve.  But, can you say why?  Or, did you just assemble and tweak parts until you felt no need to go further?  How does the possibility that you have the fastest bike on the planet help the forum if you can't explain why it works so much better?
Wait, you don't see the fallacy of that logic?
1. Of course it "works".  It is how well it works and where placed that is in question.  Remember, I do use the K&N filters.  I don't hate them.  I just noticed a fatal flaw in their sales pitch.
2. Why would they change the product if marketing and sales can sell what they have on reputation and brand loyalty in a non-competitive market area?
I haven't taken a new one apart to check.  But, I expect the same principles apply.  Other than inuendo, do you have any technical data to share with us?  Or, is your sole goal to simply denigrate someone else's work without actually providing any contrary data?
Well, I can partially agree with that, actually.  Although it is tertiary to the basic induction design.  The stock filter design does not clean during maintenance well.  But, it does a far better job of stopping smaller particles, than almost any aftermarket "free flowing" type.  So, although it actually has better "filtering performance", it comes at the cost of more frequent changes/replacement.  Perhaps that is another benefit of the stock induction, as you can change the paper to a foam reusable, to allay expenses (I have).  For around the world operation of the bike, the stock filter provides the best engine protection.  It's aggressive filtering it not actually required in all locations of the world.  So, it's not so much wrong, but better than it needs to be for many areas of operation, I think.
Why doesn't it not seem like you appreciate the work from where I sit?  Perhaps because you casually discarded all presentation summarily?
Anyway, it was not my personal goal to convince those who have no interest, in changing away from their own personal belief system.
And thanks for the non-fact relaying innuendo that OEMs are "on your side".  But, it's just not enough to sway me to your cause, sorry.
So, the goal was to help a particular forum member understand how better to make an induction system of his own design, work as well as possible by taking design cues from a proven and well working example.  And then, to share that free info with the forum membership.
If you don't like it or wish to receive it in the spirit intended, then I'll just have to live with your disappointment, I guess.  I note there do seem to be others that appreciate it for what it is.
Oh well, my monetary compensation is the same in either case. ;D ;D ;D
Somewhat sad that the time expenditure now seems ill spent on my behalf.   :(
  • The Stumped
« Reply #23 on: March 18, 2010, 02:00:38 AM »
TT, the tone of a few of the responses has been less than appreciatative. Don't be mistaken, there's not a person on here who uses the forum regularly that hasn't benefited from your knowlege, I know I have many times. Maybe the lack of a 'gee whiz!' response, where everyone finally falls in line and casts their pods into the dustbin, is whats coming off as unapreciative. I have to ask if keeping the stock intake configuration were imperative to the operation of these old bikes, why can't Honda maintain support for them by reproducing the often damaged rubber parts? A lot of guys running pods are doing it because the stock parts have simply not held up. It's one aspect where these otherwise well engineered bikes have not stood the test of time. Those parts deteriorate and there is little alternative. Could you explore, at least some of the theory, why pods do work, what their limitations are, and in what situations they might be appropriate? This way the guys who are running pods aren't instantly on the defensive and the argument is fully balanced.
And the work is appreciated, I read the whole thing.
« Last Edit: March 18, 2010, 02:02:24 AM by B.O.X.N.I.F.E. »
1974 CB550
Forever West
Offline mystic_1
  • 1970 CB750K
« Reply #24 on: March 18, 2010, 05:36:50 AM »
Any comments on intake tract lengths, TT?  Distance from valve to venturi, length of carb inlet adapters, etc?
The intake tract can be used to compress the inlet charge, if the velocity is high enough to give it some more mass effect.  Simply put, when the piston draws air into the chamber it also draws air through the duct.  The intake valve closure can make a reverse shock wave that compresses charge.  If timed correctly, the next valve open sees a denser charge entering the cylinder.  This can all be tuned for a sweet spot boost, but usually has a narrow RPM band where the valve timing, lift, runner length, diameter, etc. are all factors.  Unless you have variable valve timing, I can see this a practical for street operation, which is where the stock air induction was intended to be used.  Stock cam, stock valves, stock red line.
I think you mean "I can't see this as practical..." and it makes total sense that the pulse compression effect you describe would only be significant under certain running conditions.  Does this mean, that effect aside, that distance from the valve to the venture and from the venture to the filter media make little difference (aside from the filter being far enough away from the carb to prevent vorticies from entering the carbs)?
I think you are talking about the rubber inlet couplers instead of filters, right?
The rolled lip may help in whatever material they were created, metal, fiberglass, etc.  But note the incoming air flow to the stock ones is largely unidirectional from the plenum inlet (at least on the 550).   The illustrations posted show air being pulled not from a source 3-4 inches in front, but from a omni-directional source.  I think that may make a difference.  Though I do not know how much.
Oops, did indeed mean the carb-to-airbox inlet couplers not "inlet filters" :)
I follow what you're saying about intake air coming from a directed source instead of omnidirectionally, and it makes a lot of sense to me.
cheers
mystic_1
- John Augustus Shedd
