New rebuild. Old serviceable Honda plates, Barnet HD springs in K5 basket with K5 motor. I bolted on the clutch cover, set up the lever per manual, but I cannot get the clutch to disengage. The action at the lever feels right, but the motor remains stubbornly in gear. The plates were soaked in oil for a day or two prior to installation, but the motor has sat a few months since then. Could this mean the plates are stuck together? I am going to tear into the basket now to double check everything; is there anything I should look for? I am sure the plates are oriented to the basket correctly and the washer is installed properly. I do not know what else to check.
