Author Topic: Re: 1976 cb750...photo update!!! nov 29  (Read 6082 times)
Offline shaunzo
« on: March 30, 2010, 01:27:33 PM »
what do you guys think of this bike for $600?  apparently it hasnt been running in 13 years.  therefore it will need a battery and the carbs cleaned.  i am thinking it will be a great project.  anything i should keep in mind before i plunge?
« Last Edit: November 29, 2010, 05:44:59 PM by shaunzo »
2007 kawasaki versys 650 - everyday
2008 xl1200n nightster - somedays
1981 cm400 bobber - somedays
1983 cm450 - nodays (gf's)
1982 kz1000j2 - a project
1976 cb750k - project bike
1971 norton commando 750
Offline scartail
Re: 1976 cb750 for 600 bones?
« Reply #1 on: March 30, 2010, 01:59:05 PM »
maybe just the picture or dirt... leaky head gaskets?
'89 Hawk GT, newly acquired, daily beater...
'76 CB550, was my daily beater... my cafe project...
'72 Yamaha R5, newly acquired project... donated to my buddy...
'67 Suzuki T20, still working on her too... Currently in pieces...
Offline shaunzo
« Reply #2 on: March 30, 2010, 05:00:11 PM »
ok, ok i just got it for 500 bucks.  i am picking it up tomorrow and will take some better pics.  this is gonna be the beginning of a healthy project for sure.  i am gonna do something retarded original and build something you guys have never seen!   a CAFE!  haha kidding, i have a bobbed cm400, a slightly cafe'd 2008 nightster and somewhat restored cm450 fo the girlfriend.  all i was missing was a cb750 and now i have one....totally excited to tear it all apart!
Offline KB02
« Reply #3 on: March 31, 2010, 11:53:23 AM »
I like the CM400! That came out nice. Would love to see more pics of that.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline shaunzo
« Reply #4 on: March 31, 2010, 12:10:53 PM »
thank you, what i need to do is get some better pics  of the cm400.  i gotta admit it is really nice and im picky as hell!  i'll get some more thrown up here asap (as soon as i get back with my newly acquired 750)!!!  wish me luck...
Offline shaunzo
« Reply #5 on: April 03, 2010, 03:42:14 PM »
i like to start off by saying that this 750 that i picked up is rough.  very rough, but it is good where it counts.  Got it for 400 bucks.   i now understand why it has such a devoted following.  it really didn't take a whole lot to get it going.
i pulled the plugs to check for spark (notice the washers on the 4th plug), no spark, cleaned the points, added a small 12v battery and voila! spark.  according to the plugs the bike has been running very well up until it was stored 13 years ago.
next was fuel:  i pulled the carbs and checked them and of course they were pretty bad and needed a good cleaning.  so i cleaned them up with a bit of carb cleaner, tooth brush, a piece of wire, and compressed air.  all the passages were cleaned out and i reassembled.  of course i had to break something:  the float bowl drain screw snapped right off!
i installed the carbs, hooked up an aux. fuel tank and started kicking.  after a few pops and sputters and some disgusting black smoke she fired right up!  what a beautiful sound too!  these old bikes a breeze to work on and i now understand why they are so popular!
Offline shaunzo
Re: 1976 cb750 update april 03/10
« Reply #6 on: April 03, 2010, 03:50:48 PM »
so it runs amazing!  it sounds awesome!  a part of this must be contributed to the 4 into 1 exhaust thats on it.  from what i can tell there should be a 4 into 4 exhaust on this model (1976 cb750k).  the 4 into 1 exhaust was reserved for "f" models.  so, what is this header from?  is it an aftermarket or is it the "f" model exaust?
also, i forgot to mention that the motor is gonna need to be dissassembled, freshened up with some new gaskets and whatever else it may need to make it a strong runner.  as you can see in the pic below the head gasket leaks pretty bad.  in the pic the bike is running and you can see smoke and bubbles popping through the gasket.   do you guys have any suggestions as to what kind of things i should prolly replace engine-wise?  my direction as of now is too build a cafe bike, but no based on aesthetics only.  i want to build something that is more than just a pretty bike.  i am willing go as far as swapping the cam, but i will not bore it out.
as of now the frame will be powder-coated white, the aluminum will be polished, uneeded #$%* will be cut off.
input?
Offline BeSeeingYou
« Reply #7 on: April 03, 2010, 05:32:30 PM »
That is not an F header or muffler.  There were and are 4 into 1 aftermarket  systems available but as to what one that is I am not sure.
« Last Edit: April 03, 2010, 05:37:44 PM by srust58 »
Offline shaunzo
Re: 1976 cb750 update 0ct. 1st
« Reply #8 on: October 02, 2010, 06:13:53 AM »
yup, im slow.  but if i can ride i'm gonna ride. the bike building can wait until winter has locked me in the basement with my 750...or can i wait?
i have torn everything off of the bike that i wont be reusing except for the front end.  i love the look of the stock tank and will be keeping that.  i will fabricate a tail piece out of an old RV hot water heater and polishing it to keep with the white/aluminum look.
looks like i will be throwing a front end off of a 2005 zx636 onto this one and may match that with a swingarm off of a 2009 er6n (single-side mounted shock like my Versys).
i have some rear sets off of a 2005 'busa on the way as well.
i will keep you updated on the front end fittent.
laters...
forgot how to post pics...
Offline shaunzo
« Reply #9 on: October 02, 2010, 06:36:28 AM »
pics:
Offline shaunzo
few improvements since the last post.  was able to get a mock-up done.  so im using a 2005 zx6r front end, wheel, brakes, and a 2009 er6n rear swingarm, wheel and brakes.  got everything in place and with the help of a local machinist should fit nice and snug.  the front end will require the steering stem to be milled down to accept the original 750k head bearings and the rear portion of the frame will need to be widened a few mm's to accept the er6n swingarm and shock mount.  overall this is going pretty easy.  at this rate it will be a winter project only and should be on the road for early summer.  here's a few pics of widening the frame, the old front end and finally, the mockup (yes i am keeping the stock tank...i love the look of it.
PS...I HATE RESIZING IMAGES FOR THIS SITE!
also, how do i change the topic to reflect updates?
shaunzo
« Reply #11 on: October 18, 2010, 07:33:46 PM »
Open a free account at photobucket.com Then upload your pics there, it will resize them automatically.
PS. nice project!
Offline Old75_ratafe
  • CB750 Cave Spelunking
  • 1975 CB750K
« Reply #12 on: October 18, 2010, 11:42:57 PM »
This is gonna be an interesting one  ;D
1975 CB750K
Project Back in Black
Offline shaunzo
Re: 1976 cb750...ZX6 front end & ER6N swingarm nov 28
« Reply #13 on: November 28, 2010, 12:29:42 PM »
ok, ok, ok not really an update...  the plan is to upload my entire build to photobucket and open it up so you guys can follow along.  working on this now...shaun
Offline shaunzo
« Reply #14 on: November 28, 2010, 04:25:52 PM »
please check out the cb750 albums where i have documented all of my progress thus far on my 750.  lemme know if this even works...laters
http://s977.photobucket.com/albums/ae258/cornerbrookcustoms/
hope this works
Offline Flying J
Re: 1976 cb750...huge photobucket update!!! nov 28
« Reply #15 on: November 28, 2010, 04:56:35 PM »
Looks sweet, Im interested in the details on your for k conversion and swingarm swap.
Re: Re: 1976 cb750...huge photobucket update!!! nov 28
« Reply #16 on: November 28, 2010, 05:05:18 PM »
Bad link
Offline shaunzo
« Reply #17 on: November 28, 2010, 05:10:23 PM »
how about this?
i am new to this photobucket crap...let me know if anyone has any ideas as to how to properly link it...
