Author Topic: Constant voltage  (Read 569 times)
Offline boatsdickson
  • 1978 836 K8
Constant voltage
« on: March 30, 2010, 05:07:40 PM »
Drawing nearer to finish on my 750k8 rebuild, I hook up the battery and my headlight and taillight come on. Also the dash lights are all on. The ignition is off and non of my other lights are on: meaning the four running lights. If I turn the ignition to on position, the four corner lights will come on. Turn the key off and the problem returns to its original state, headlight and taillight only.
Ive spent a day now checking components and referencing the shop manual but I still have more to go. Im bettin my answer will pop up on the forum before I isolate it myself. Anyone else seen this issue? ..... 8)
"No. We're all our own prisons, we are each all our own wardens and we do our own time. I can't judge anyone else. What other people do is not really my affair unless they approach me with it. Prison's in your mind. Can't you see I'm free"?  Testimonial of Charles Manson
Re: Constant voltage
« Reply #1 on: March 30, 2010, 05:34:11 PM »
Only the front should have running lights, and dual element bulbs.
The rear are for turn only and single element.
You hooked things up per Honda shop manual?  (Probably not if you have rear markers.)
Better check the color codes of the wires are matched up.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #2 on: March 30, 2010, 05:55:48 PM »
Check your ignition switch,red hot all the time,blk should be switched hot,sounds like you have power in blk wire w/switch off.Bill
BentON Racing Website
BentON Racing Facebook
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #3 on: March 31, 2010, 05:29:59 AM »
+1.
