Author Topic: Will the center stand allow disassembly?  (Read 1158 times)
Offline robdrobd
  • Who? Me?
  • Isn't she a beauty?
« on: March 30, 2010, 07:30:24 pm »
Will the centerstand support the bike enough to remove the rear wheel?
Offline Elkie
Re: Will the center stand allow disassembly?
« Reply #1 on: March 30, 2010, 07:45:53 pm »
Yes
Offline bird
« Reply #2 on: March 30, 2010, 07:50:59 pm »
Tip: Put a 1/2 -1 inch block of wood under each leg of the stand. Helps elevate the bike a little to get the wheel out easier. Chock the front wheel with a brick or something heavy, just to be safe, so the whole show doesn't roll forward. ^^
Offline scroggins5000
    • scroggins5000.com
« Reply #3 on: March 31, 2010, 12:32:14 pm »
Yeah, but you do risk it getting bumped and moving forward. If that happens, the center stand could spring back up and then you have a frame on the ground. I just used a milk crate with padding on the top.
Offline bird
« Reply #4 on: March 31, 2010, 10:33:07 pm »
Point taken. But if you chock the front wheel, it shouldn't roll forward, unless you're heavy handed with the rear wheel removal. Fours are pretty well balanced. ^^ But if you're really nervous, put something heavy on the back of centre stand legs and she won't pop up. Have fun!
Offline Fritz
« Reply #5 on: April 01, 2010, 01:48:54 pm »
And zip-tying the front brake lever might be a good idea too.
1976 CB550F
Offline lone*X
« Reply #6 on: April 01, 2010, 03:27:08 pm »
Had my 75 550 from new and have always done my own maintenance and tire changes.  Every time it was done on the center stand.  I have put a 2x6 under the stand to get a little more elevation but it makes it harder to get up on the stand.  Just more lifting.  I have never had an issue with stability.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
