Author Topic: Weber carb set-up  (Read 151836 times)
Offline jonnycakes
Re: Weber carb set-up
« Reply #575 on: July 01, 2015, 03:32:04 PM »
I'm so close...put in the 28mm 110 main 150 air (smallest I got) and 40f9.  Starts right up and idles when warm. Will pull if I roll slowly the throttle (no squirter) and when whacked hard(squirters). Still feel like it's going rich when at speed I close and then reopen the throttle. It takes a sec to clear its throat.
'Matic-Fanatic
Offline BPellerine
« Reply #576 on: July 01, 2015, 05:55:27 PM »
did you try a plug chop?when it does clear how is the response?
1978 CB 750K ard and webers
another anfob
Offline jonnycakes
« Reply #577 on: July 01, 2015, 06:46:34 PM »
YUP...looks good in the idles, looked good top end. Went to the 28mm chokes to make sure I was bring in the mains early.
'Matic-Fanatic
« Reply #578 on: July 01, 2015, 07:25:07 PM »
Where are your idle mix screws set with the 40s?
Offline jonnycakes
« Reply #579 on: July 02, 2015, 11:46:19 AM »
1 full turn
'Matic-Fanatic
« Reply #580 on: July 02, 2015, 10:26:08 PM »
Everything about your set-up is lean, except for the 150 airs, which only kick in at higher RPMs. When cruising at a steady 65 MPH, I'm still mostly on the pilot jets. The early carbs like ours with the wider angle mixture screws should be 1/2 +/- turns out with the proper jets. Without changing anything else, go back to the 45s and report back.
Offline jonnycakes
« Reply #581 on: July 03, 2015, 04:38:25 AM »
Great idea, I'll do it and report back. Thanks for all the help
'Matic-Fanatic
Offline jonnycakes
« Reply #582 on: August 28, 2015, 02:44:53 PM »
I went with the 30mm 120 main 170 air and 40f9 idle.  Starts right up and idles when warm. Run great but a little stumble off idle when cold and warm, Maybe back to the 45s idles?
'Matic-Fanatic
Offline BPellerine
« Reply #583 on: August 28, 2015, 05:50:50 PM »
must be diff with the auto,only tried two sets of webers and both had quick throttle response on the lower end,my own better than the other set cause they had diff jetting.bill
another anfob
Offline Tintop
« Reply #584 on: August 28, 2015, 08:14:46 PM »
Could be your accel pump jet size, or the bleed back size.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline BPellerine
« Reply #585 on: August 29, 2015, 09:08:42 AM »
one thing I did notice when I was getting mine ready,I had the top off the carb and was pumping cleaner through it,this showed bubbles coming out of the pump jet orings and the screw that holds the stuffing ball,I was losing pressure in these places to the pump,doing this showed me a little about how the fuel flows as well.bill,it cured a small hesitation I had
another anfob
« Reply #586 on: August 29, 2015, 06:15:56 PM »
The 45s worked best for me.
Offline jonnycakes
« Reply #587 on: September 02, 2015, 09:18:25 PM »
After much trial and error:
30mm chokes (32mm chokes too big, 28mm chokes too small)
4.5 Aux Venturi
F16  Emulsion Tube
120 main (125 main way too big)
45F8 Idle jet (40F9 Idle jet just a bit small)
35 pump jet
Pump Spill  55 (what is stamped)
.200 needle valve
170 AIR CORRECTOR JET
running 120mph on the highway, and a touch of wheel spin when i wack the throttle at low speed.
DONE
'Matic-Fanatic
« Reply #588 on: September 02, 2015, 09:39:08 PM »
I had my bike on the dyno on Monday, and found it to be way too rich above 4500rpm with 125 mains. Before I could change anything, the drum bearings on the dyno started making ugly noises. :o New bearings are on the way. I was going to try 32mm chokes first, because I think I can change them without removing the carbs, unlike the mains with the Seeley frame. I do have a set of 120 mains, so your news is encouraging. ;D
Offline johno
« Reply #589 on: September 03, 2015, 01:50:03 AM »
Johnny gogo,
Your finished carb specs are almost identical to what I used to run on a few of my 750 honda's with cam, ports and rc exhaust and 30choked webbers.....32 was to big and 28 too small , jets stuff all the same as you ended up with, run nice.
 ;D
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
Offline BPellerine
« Reply #590 on: September 03, 2015, 09:03:23 AM »
great news ,I have 29mm chokes 115 mains and 200 airs,so I am not that far from you,everything else the same,maybe need small change with bigger motor when that happens.billp
another anfob
Offline jonnycakes
« Reply #591 on: September 11, 2015, 05:45:21 AM »
Now to ride.....
'Matic-Fanatic
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #592 on: September 20, 2015, 12:16:20 PM »
Bill,
Thanks for the previous info.  I'm going to set the ones up from Bill Benton on my stock (for now) K4 motor.  Bill pulled them from a drag bike..so I guess my question is: which pieces will I likely need to swap to get it to run on a smaller motor for the street?  I have master rebuild kits coming in next week, then I'll disassemble one at a time and dip in some magic sauce at the shop.
« Reply #593 on: September 20, 2015, 01:11:25 PM »
The chokes are the main thing you made need to change, depending on the size of the motor. What parts are included in the rebuild kits? Don't soak the accelerator pump spill jets in the magic sauce, as they have a plastic ball inside, and the magic stuff may damage them.
Offline BPellerine
« Reply #594 on: September 20, 2015, 02:21:47 PM »
Bill,
geggo,when you get your carbs record all the diff jet values,and your choke and aux venturis,then compare to what you see on here ,you will get a ballpark setting and then you may have to tune some.the stock motor is about as small as these carbs run on ,just my opinion,so you have to be fairly close,ie not too big.I have only been running mine for a couple of years,scottly much longer.bill
another anfob
Offline BPellerine
« Reply #595 on: September 20, 2015, 04:20:51 PM »
I do not use strong cleaners,wd40,brake cleaner,small brushes,and air.these carbs are made out of a metal called mazac very crappy metal that will crack easy.there is finish on them that chips and you end up with a dark spot that you can clean but come back quick,I just live with it.I have seen these carbs painted,and even chromed but I could not imagine what it would take to do that.they have some detailed parts and passages that I would not blast.you can buy a lot of stainless for them.bill
another anfob
Offline Bill/BentON Racing
    • BentON Racing
« Reply #596 on: September 20, 2015, 06:49:48 PM »
Gregg, I found that stock ignition wouldn't be enough at slow speeds, idle etc. Went to a RC distributor setup, and no more problems.  Stock 736cc 750 model, 30mm chokes, Bill
BentON Racing Website
BentON Racing Facebook
Offline BPellerine
« Reply #597 on: September 20, 2015, 06:59:42 PM »
been holdin back bill?haha when I got mine I searched for someone that had run them on 736,most 836 and up.billp
another anfob
Offline Greggo
  • Somebody's
« Reply #598 on: September 20, 2015, 11:45:00 PM »
I'm glad I asked...I'll just clean them carefully by hand.  Some rusty spots I spritzed with Kroil.  Haven't seen the rebuild kits yet..next week.
Was going to use a Dyna III on this bike...good 'nuff?
« Last Edit: September 20, 2015, 11:46:38 PM by Greggo »
« Reply #599 on: September 21, 2015, 01:39:07 AM »
Yes... ;)
