Hi guys,
I picked up a set for the Seely.
Starting to go through them....a bit of a strange set up. They came off an 812 Yosh race motor.
45F9
130/122
200
F15
35
He was running 122 mains one the outer cylinders and 130's on the inner cylinders?
He was also running #1 aux. on the 2 insides and #2 on the outside.
Running 30 chokes across the board.
So it came with 4 each 30 and 32 chokes and one isnt stamped, but measures 30.
4 each of #1 and #2 auxiliaries.
Any thoughts on that?
It came with an MPD that is in two pieces. He said that he did that because they were easier to fit.....maybe he just broke them and went with it...who knows?
Any thoughts on running a 2 piece manifold....as long as I secure them well at the entry end?
One more question....what are most of you running...filters (is there enough room?) open air horns or air horns with mesh or filter socks on them?
Okay one more question. I read on here about a ball to be careful with....I have found none but there are a couple of 1/2 inch metal pieces, rounded at the ends, that may be doing the same thing? Is that common?
Thanks for any help that you can give me.
Steve
Thanks
