Author Topic: Weber carb set-up  (Read 151714 times)
Offline valt
Re: Weber carb set-up
« Reply #900 on: January 11, 2019, 07:54:10 AM »
This is another linkage version.  I used this on the sidecar, worked very well with a nice smooth pull.  Does require a return spring, but all Weber set-ups hould have one.
https://www.piercemanifolds.com/product_p/pm40930.htm
Yah that again does not work with the R.C. manifold setup as its meant for a straight pull.
Offline gschuld
« Reply #901 on: January 11, 2019, 05:24:19 PM »
I have a question for everyone, apologies if it has been mentioned before. But I have a R.C. manifold with a pair of DCOE 40s on it. What I want to know is what throttle lever to use, all of the weber ones I can find are for cars and don't allow you pull direction up on them. I have circled the part I am talking about in red in the picture below.
This is the RC Webers setup on the Vance and Hines double.
Offline gschuld
« Reply #902 on: January 11, 2019, 05:29:07 PM »
RC catalog pics
Offline gschuld
« Reply #903 on: January 11, 2019, 05:29:59 PM »
More:
George
Offline gschuld
« Reply #904 on: January 11, 2019, 05:35:10 PM »
Close up views of the (left) sides of the Vance and Hines front and rear Weber sets.  Both are spring loaded to counteract the pull of the throttle cables.  Couldn’t tell you if there were any other uses to it.
George
« Reply #905 on: January 11, 2019, 06:13:06 PM »
Boy those springs are no tension at all.
Offline Tintop
« Reply #906 on: January 11, 2019, 06:26:21 PM »
Thanks for posting those George.  So basically the cable linkage is made up of 4 pieces each side (2 levers, cable stop, & return spring).  You don't want a lot of initial spring tension on a bike, hard on the wrist, just enough to make sure the throttle closes.  Different situation in a car. ;)
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #907 on: January 11, 2019, 06:36:57 PM »
In the first pic, the two levers on the left would match the clocking and possibly length required for the RC manifold, but the lateral off-set will only work on the right side. These levers lack the idle speed tabs, but can be fit on top of levers with the tabs. There a wide variety of levers regarding clocking, length, and handedness, and when all else fails, it's easier to weld onto an existing center than start from scratch. ;)
Regarding springs, my original carb's internal springs were strong enough that external springs were not required. I recently fitted a set of newer, less abused carbs, and it turned out the internal springs were not as strong, and I had to fit external springs. ( I would have swapped the internal springs, if I could have figured out how to remove them without destroying something; those suckers are on there for life!)
« Reply #908 on: January 11, 2019, 06:55:58 PM »
What I'd like is a progressive throttle; the first 20 degrees of the throttle would open the throttle blades less than the last 20 degrees with a 1/4 turn throttle. As is, the transition from idle to low throttle openings can be somewhat abrupt. I once used one of the idle speed screws as a cruise control while on a lonely Nevada highway to maintain 60 MPH.
If the spool were a spiral, or snail, this would be possible...
Offline gschuld
« Reply #909 on: January 11, 2019, 07:26:13 PM »
Apparently this was a common setup
George
« Reply #910 on: January 12, 2019, 06:59:10 AM »
What are they saying about which throttle cable is typically used?
« Reply #911 on: January 12, 2019, 08:29:30 AM »
On the RC , I bet CB 350 twin cable..
That is what they used, cut the ends off and tin them...  unless you use wheel type..
 Not sure if the threaded part is slit on the RC, I think not.
« Last Edit: January 12, 2019, 09:32:33 AM by 754 »
Offline Tintop
« Reply #912 on: January 12, 2019, 08:50:33 AM »
Interesting they have used the throttle arms ( l & r) for the return spring that are normally used for a 'push' link that have the ball.  The other piece looks like a cut down version of the flat arm with multiple adjustment holes.  Motion Pro could certainly make a dual cable.
77 CB550 Cafe build
« Reply #913 on: January 12, 2019, 09:35:39 AM »
They don't need much tension, the throttle opens easily with 2 fingers..very light pull. Slides have way more friction.
Scottly I am thinking if you make the wheel type  and make the mount hole off center, you may get what you need.
« Last Edit: January 12, 2019, 08:33:33 PM by 754 »
Offline BPellerine
« Reply #914 on: January 13, 2019, 05:24:01 PM »
450 cable is the one I found that worked with the rc man,350 too short on the carb side,the 450 cable just fits with not much to spare,oem cable.bill
1978 CB 750K ard and webers
another anfob
« Reply #915 on: January 13, 2019, 06:05:47 PM »
 I wish I had a pic of a gl1000 throttle wheel, they appear to be something that might be adaptable.
« Reply #916 on: January 13, 2019, 09:14:59 PM »
Does it look like this  ?
Offline valt
« Reply #917 on: January 14, 2019, 06:11:54 AM »
George
Hey George,
That setup appears to be two pieces. I wonder if the part of the lever that the throttle cable connects to is keyed to the weber throttle shaft. Or if its just a hole drilled and they are relying on the nut to hold the lever tight to the keyed lever that the spring connects to.
Offline valt
« Reply #918 on: January 14, 2019, 06:53:49 AM »
George
The second pic here is from Kiyos bike. That actually looks like a production lever and not just something he made. I did email him and ask but I think he misunderstood exactly what I was asking him. I suspect that lever comes from a different carb but I am not able to find out what.
Offline gschuld
« Reply #919 on: January 14, 2019, 07:19:19 AM »
George
Unfortunately, I can’t shed much light on the subject beyond the pics.  I’ve got an RC history interest, but I have never felt inclined to own a Weber carb setup.
George
Offline BPellerine
« Reply #920 on: January 15, 2019, 04:35:14 PM »
on the subject of the rc manifold,it just ocurred to me that maybe they used ko carb boots on them to make them fit the stock frame,they are shorter than the later boots,and maybe would let the carbs sit level?bill
another anfob
« Reply #921 on: January 15, 2019, 06:00:45 PM »
I finally got a set ok K7/K8 boots. Shorter? and 1mm larger carb opening. Won't get to install them until April.
Offline valt
« Reply #922 on: January 16, 2019, 05:54:28 AM »
I just use the inner two boots from a normal k setup. DCOE 40s also do not want to be completely level anyways to my understanding. For them to function properly they need to have a bit of angle to them.
Offline Tintop
« Reply #923 on: January 16, 2019, 09:05:18 AM »
Actually they should not vary more than 5* from horizontal, otherwise the float level changes.  If not supported they will sag on the rubber boots.  On the CB750 most use the original air cleaner mounts, and fabricate a mount for the top of the carb(s).
77 CB550 Cafe build
Offline BPellerine
« Reply #924 on: January 16, 2019, 05:21:01 PM »
yes they are shorter jerry,main issue will be if they seal when tightened,and yes I do kind of remember having to use 4 of the same boots,inner?bill
another anfob
