Author Topic: CB750 KO Weak Idle Cylinder Suspects  (Read 1429 times)
Offline Simpson
  • I ain't no
  • Aged to perfection
« on: April 01, 2010, 08:19:24 AM »
Somehow I have a weak firing piston in my #3 cylinder during idle. .
Symptoms, uneven idle especially when cold, significantly cooler pipe (I can hold on to it), low air pressure coming from tail pipe.
Here's what I've done:
Checked spark - Consistent, strong
Spark plug after cold start idling for few minute- Very dry and brown resembling, seems to fire up all gas provided
Triple checked intake leaks with new clamps- Balancing idle sync seems normal with vacuum pressure gauges
Float Bowls check - Swapped with another side and still get same result
Idle Jet - Swapped out different idle jets, even up to 43-44 with same result
Air screw - Has little impact, fires maybe better when turned in all the way
Compression test - Performed few months ago
cyl #1 - 158
cyl #2 - 150
cyl #3 - 155
cyl #4 - 155
Seems to fire fine off idle circuit...
ARGH!
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: CB750 KO Weak Idle Cylinder Suspects
« Reply #1 on: April 01, 2010, 09:05:50 AM »
You sure all the air and fuel passages on # 3 carb are clean? Compressed air/wire in all holes clean?
I had the same problem on my #2 until I had to reclean them and voila! It worked.
Offline Simpson
  • I ain't no
« Reply #2 on: April 01, 2010, 09:18:04 AM »
Seems like that would be the most likely at this point. I took 100 psi to it this winter on all the circuits. Is there a chance that a nasty deposit will not break free? Wonder how I can test that...
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Simpson
  • I ain't no
« Reply #3 on: April 01, 2010, 09:53:44 AM »
Perhaps it weak all the way around, meaning off the idle jet also...
1970 CB750 K0
1975 CL/CB 360 Mix
« Reply #4 on: April 01, 2010, 10:47:22 AM »
Run the wet compression test for #$%*s and giggles to see if your pressure significantly changes.
I would reclean the carbs and recheck float levels (with a clear tube hooked up to the drain screw).
Offline Simpson
  • I ain't no
« Reply #5 on: April 02, 2010, 07:37:00 AM »
Took air box off blew air through all ports, swapped spark plugs and wires...
Starting to think I have low compression.
Have to recheck compression this weekend.
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Simpson
  • I ain't no
« Reply #6 on: April 02, 2010, 08:29:44 AM »
Riding back from the post office it comes to me.  :o
 I bet my tappets somehow got wacked when I put the bike back together. It would explain everything.
Now to let the bike cool.
1970 CB750 K0
1975 CL/CB 360 Mix
