Author Topic: stranded need help!  (Read 1133 times)
Offline xfactor
stranded need help!
« on: April 01, 2010, 10:22:37 am »
I was out riding today when I pulled over. I accidently turned the key to the right and put on the P brake light. After turning her back to the off postion and removing the key i noticed the P brake light was still on. I have tried several times to move it to the ON position but to no avail, it just feels loose and I cant start her. Please any suggestions would help greatly.
Croix
Offline kopptl
Re: stranded need help!
« Reply #1 on: April 01, 2010, 10:30:53 am »
try giggling the key,, my cl175 had a simlar problem.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #2 on: April 01, 2010, 10:34:15 am »
If your Honda ignition is like the ones I've seen (on my 500/550's) the plastic box on the bottom can be removed and serviced.  That's where the electrical connections are being made.
You can always hotwire the bike, bypassing the keyed ignition.  Sounds like your switch might be shot.  If you want to keep your ignition key matched to your seat lock (if you have one) then you'll want to swap the contact mechanism off another good ignition onto yours.
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
Offline xfactor
« Reply #3 on: April 01, 2010, 10:37:00 am »
sounds like i need a new contact mechnism. Any idea how i can go about bypassing the key ignition? I dont have any tools on me, but there is an auto parts store near by.
Croix
Offline mystic_1
  • 1970 CB750K
« Reply #4 on: April 01, 2010, 10:48:19 am »
What bike?
If it's a 750 K0-K6 with the key under the tank, unplug the 4-prong ignition connector and connect Red to Black, and Brown/White to Orange.
That will get you home.
I think the color codes are the same on a lot of Honda models.
mystic_1
- John Augustus Shedd
Offline xfactor
« Reply #5 on: April 01, 2010, 10:52:23 am »
its a 750f
Offline mystic_1
  • 1970 CB750K
« Reply #6 on: April 01, 2010, 10:57:03 am »
750F has the key on the triple tree yes?  Still has the same four wires with the above mentioned color codes.  Follow wiring from switch until you find the first modular connector, disconnect it.  On the older round connectors, you'd connect the four pins using an X pattern, connecting each hole to it's diagonal opposite.  Not sure of the arrangement of the modular plugs on later models or F models.
Red to Black at the key switch connetion gets your ignition going.  Connect the other two wires to get your taillight and running lights.
best of luck
mystic_1
Offline xfactor
« Reply #7 on: April 01, 2010, 11:27:08 am »
what kind of damage did I do if the red wire got grounded out?
Offline xfactor
« Reply #8 on: April 01, 2010, 12:17:12 pm »
Nevermind luckily the PO had fuses not bolts in the fuse box.
