Author Topic: Sandblasting inside of tank?  (Read 3706 times)
Offline prince_ruben
« on: April 01, 2010, 06:29:42 PM »
Does anyone know of the shop that sandblasts inside tank then coats them?
traveler
Re: Sandblasting inside of tank?
« Reply #1 on: April 02, 2010, 05:30:13 AM »
unnecessary.
Do a search.  A good cleaning with "The Works" and a final cleaning with baking soda and water mix to keep flash rust away, and it will look like new.
If that won't do it.....then it's best to get another tank.
~Joe
Offline Old Scrambler
« Reply #2 on: April 02, 2010, 09:20:02 AM »
+1 with Traveler ...........I have my tanks steam-cleaned and have a modern liner applied by a radiator repair shop who also does gas tanks.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #3 on: April 02, 2010, 10:29:00 AM »
I removed all the rust in my tank with Evapo Rust; works great. However, I lined/sealed the tank with Red Kote and I fear that the Red Kote is breaking down do I'd like to remove it and start from scratch, thus spawning my interest in sand blasting (or whatever method to remove the Red Kote).
R.
Offline Caaveman82
  • Zippo
  • That'll do pig. That'll do.
« Reply #4 on: April 02, 2010, 10:36:42 AM »
Another member once recomended POR15 to me. It seems like a solid product, he said it has been a handful of years and still going strong, when I get my tank back I will be going that route.
Offline Frankenkit
  • Industrial Strength
« Reply #5 on: April 02, 2010, 12:05:16 PM »
there's a local shop that does media blasting with walnut (or hazelnut?) shells for Western Cycle before they sell them. My 650 tank was done that way, and the results look beautiful.
I'd try the Works first, though (be sure to follow up with enough baking soda + water to neutralize the stuff, or you'll flash rust bad)
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline Gregorymoto
  • SOHC Aficionado
« Reply #6 on: April 04, 2010, 09:23:16 AM »
Where do you live?
Yep, i have issues with this sort of stuff.
traveler
« Reply #7 on: April 04, 2010, 09:36:52 AM »
keep in mind sandblasting will warp the crap out of the sheet metal.....your tank will requrie ALOT of mud (bondo) to get back to where God and Honda intended it to be....I guess media blasting is an option....Still, The Works and a good sealant is the way to go, IMHO.
~Joe
Offline Frankenkit
« Reply #8 on: April 04, 2010, 09:48:53 AM »
Portland metro, OR
1973 CL350- Lola?
Stuff for sale
« Reply #9 on: April 04, 2010, 11:39:28 AM »
My radiator shop tells me you can apply more Red Kote over the old after it is thoroughly cleaned.  It disapates with time.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Offline greasy j
  • lanesplitting
  • non serviam
« Reply #10 on: April 04, 2010, 05:25:10 PM »
if it's like other tank liners it thins with methyl ethyl ketone(mek). that may work as a solvent if you soak it for a bit. if you reapply just prep it right first with weakened metal etch or similar and it should hold. I have a lined tank that has been good for 4 yrs or so now.
« Reply #11 on: April 04, 2010, 05:56:07 PM »
This is probably more than you had in mind, these guys work wonders on pretty bad tanks.
http://www.gas-tank.com/bike.htm
Not cheap, but you asked who sandblasts the insides and they do. They cut them open, blast them, repair them, weld them back up, coat them, prime them and return. Pretty amazing, but again probably more than you had in mind.
Offline Gregorymoto
  • SOHC Aficionado
« Reply #12 on: April 05, 2010, 07:49:04 AM »
Sandblasting will warp the tank? Aaaaaaaa.
I have never experienced that.
traveler
« Reply #13 on: April 05, 2010, 09:00:00 AM »
sheet metal has a tendency to warp when sandblasted.
~Joe
« Reply #14 on: April 05, 2010, 09:27:18 AM »
The " I will do it for 20 bux (in 5 minutes  :o) if you bring it over while i am doing a big INDUSTRIAL job".. using an inch and a quarter hose.... them guys EXCELL at warping stuff....
