Author Topic: Master Cylinder replacement  (Read 2723 times)
Offline Scott S
« on: April 02, 2010, 05:45:26 PM »
 Is there a suitable aftermarket master cylinder replacement available for a CB500/4? What is the stock bore so I can shop around?
 Is it worth rebuilding the stock M/C?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Johnie
Re: Master Cylinder replacement
« Reply #1 on: April 02, 2010, 06:02:55 PM »
Fairly simple to rebuild the MC. Here is a pic of what the parts look like. The right half of the pic shows the kit I am installing. The left side just shows what I took out. The OEM kit for my 750 was about $40 from my dealer
« Last Edit: April 02, 2010, 06:04:38 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline MoTo-BunnY
  • The 'Torque 'er Down 'till it Strips Then Back 'er Off a Quarter Turn', Type of
  • 1973 CB500 ~ member #3791
    • http://instagram.com/moto_bunny#
« Reply #2 on: April 02, 2010, 06:37:59 PM »
No offense, but I know this subject has been covered MANY times previously and those very informative posts surely can be found with just a bit of searching here on the forums?
Just using your own words, "master cylinder replacement" brought up three pages worth of previous posts:
http://forums.sohc4.net/index.php?topic=64178.0
http://forums.sohc4.net/index.php?topic=18045.0
http://forums.sohc4.net/index.php?topic=51070.0
http://forums.sohc4.net/index.php?topic=41098.0
http://forums.sohc4.net/index.php?topic=12934.0
http://forums.sohc4.net/index.php?topic=12664.0
http://forums.sohc4.net/index.php?topic=62759.0
etc, etc, etc. . . .  .
« Last Edit: April 02, 2010, 06:43:26 PM by MoTo-BunnY »
---> instagram.com/moto_bunny# <---
[img width= height=]http://farm4.static.flickr.com/3440/3846213109_ae572002d4_o.gif[/img]
hoppin' on down the bunny trail . . .
1973 Honda CB500K2
1970 Ding-How aka Nova R-S w/3.5HP Tecumseh MiniBike
1970 Taco Model 22 deluxe w/3.0HP Briggs & Stratton MiniBike
1973 GMC Vandura 3/4 Ton Van (350CID V8)
1973 Dodge "Chinook" RV (360CID V8)
1985 Toyota Tercel Wagon SR5 (4WD - 3A engine)
1982 Toyota Pickup Truck (2WD - 22R engine)
1962? DriveX Pack-Mule (Tote-Gote clone)
1989 VW Jetta GLi 16V
1991 Diamondback Mtn. Bike
Offline fastbroshi
  • Puppet
« Reply #3 on: April 02, 2010, 07:07:44 PM »
Yes, but lots of production bikes' master cylinders will readily switch over and work just fine provided they have the same thread for the banjo bolt.
I think it's 14mm, I may be wrong.
Not to me, I just had a hell of a time getting mine apart!  That and the 1970s level of performance from the stocker have kept me from rebuilding it.  I'll be getting one of these soon (I have clubmans):
http://cgi.ebay.com/ebaymotors/FRONT-BRAKE-MASTER-CYLINDER-FZR750-FZR1000-XS650-XJ650R_W0QQitemZ120550349374QQcmdZViewItemQQptZMotorcycles_Parts_Accessories?hash=item1c115c5a3e
Or for standard bars, I've seen good reviews on this site for this one:
http://cgi.ebay.com/ebaymotors/FRONT-BRAKE-MASTER-CYLINDER-CB400-CB450-CB550-NIGHTHAWK_W0QQcmdZViewItemQQhashZitem1c115a45faQQitemZ120550213114QQptZMotorcyclesQ5fPartsQ5fAccessories
Just call me Timmaaaaay!!!
Offline Scott S
« Reply #4 on: April 03, 2010, 02:52:51 AM »
 None taken. I do use the search function. One thing that cripples me is that many of the results come up in reference to CB750's (or a 400 or 350, etc). I'm working on a 500 and have yet to learn all the stuff that swaps over, interchanges, etc.
 Also, many of the threads in the search results are old and pictures and links no longer work, so they're not always as helpful as you'd think.
 I'm very new to the SOHC's and will probably continue to ask seemingly dumb questions. I will also continue to use the search.
« Last Edit: April 03, 2010, 02:59:46 AM by Scott S »
'71 CB500 K0
'81 Yamaha XS650
« Reply #5 on: April 03, 2010, 03:09:09 AM »
i had to have mine sleeved,next time ill use some thing else,,if you dont need or want a genuine look,ill bet theres plenty of other options from most jap makes,even if the bore was smaller,it would only give you more pressure at the pad,for more stroke.
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« Reply #6 on: April 03, 2010, 05:39:26 AM »
I just re-anodized my MC in the back yard. Bought a 14mm flexi-hone per the book and put in the new guts. Brand new. My opinion the only things needing replacing in those kits are the rubber pieces. I wish I could find a place to just buy those. The springs, washer, valve, circlip all seem perfectly usable in a rebuild.
Oh by the way I noticed David Silver Spares juts starting selling a master cylinder for the CB750s. It doesn't look exactly stock but it's close (and brand new)
Offline Johnie
« Reply #7 on: April 03, 2010, 06:37:44 AM »
If you do it yourself you will need a long cir-clip pliers to get that clip out. I just finished the MC and caliper rebuild on my KO, K1 & K4. What a nice difference. If you do it yourself be sure to get the Honda OEM kit and do not waste your money on the aftermarket stuff.
Oshkosh, WI  USA
Offline Gonzowerke
  • I burn asses like a Bhut Jolokia, 'cause I'm a real
  • Member #106, Owner of the ORIGINAL Frankenbike!
« Reply #8 on: April 03, 2010, 07:11:35 AM »
If you are not concerned about stock looks, the MC from an early 90's CBR600F works real good. It is what FrankenBike is wearing. The rebuild kit was cheaper too...
1977 F2 "Highway Star"
1977 F2 "Bike-In-A-Box"
1978 K8 "Frankenbike"
1991 CRX Si "Buzz Bomb"
2000 Jeep Wrangler "UBoat"
2011 BMW S1000RR "TIE Fighter"
Offline Zaipai
    • My Home page
« Reply #9 on: April 03, 2010, 07:17:40 AM »
I am doing this to mine, thanks for the links very helpful!!!
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline fastbroshi
  • Puppet
« Reply #10 on: April 04, 2010, 11:05:30 PM »
That right hand button pod works great too, but you can't use the throttle tube.  No big deal, because a 550 tube works perfectly in there.  Just get yourself a wiring diagram for the 600 and once wired up it works okay.  It also has female leads off of it for a mc with a brake switch on it, like the ones I linked to.
