Author Topic: 77 550f wont idle  (Read 1026 times)
Offline governor
  • ULTRA MEMBER!
  • Yeah.
77 550f wont idle
« on: April 03, 2010, 04:11:42 PM »
Hey everyone. I recently replaced the points, condensors, and plugs on my bike. Now it only roars to life when I'm giving it about half throttle. When I let go the bike dies. I've checked my timing over and over, seems right. Battery is 100%. Any ideas?
Re: 77 550f wont idle
« Reply #1 on: April 03, 2010, 06:18:39 PM »
Gas tank have anything other than gas in it?  rust?
 Carb pilot jets clogged?
No air filter?   You sure its and F model and not a K model with the PD carbs?  You have a choke lever or a choke knob (as found on PD carbs)?  No, I don't think you are crazy, but prior posters have been mistaken.
Are all head pipes getting hot?
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #2 on: April 03, 2010, 06:35:45 PM »
Double check your points gap and timing.  Also, new points come with a coating to keep them from rusting in storage.  Clean and polish the points faces with a clean, white, non-glossy business card dipped in brake fluid.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline governor
  • ULTRA MEMBER!
  • Yeah.
« Reply #3 on: April 03, 2010, 08:29:07 PM »
I'm sure its an f model, choke lever and VIN agree. I should note it was running fine before I charged the battery (used a battery tender so I don't think I fried it. It was running better with completely knackered points, ill post a pic of before after.
mgautreau
« Reply #4 on: April 04, 2010, 10:22:11 AM »
Since the touble started after you replaced the points/condenser it's probably related.  It is hitting on all 4 cylinders?  Start it up briefly and then feel the exhaust pipes to see if they are all warm.
Offline governor
  • ULTRA MEMBER!
  • Yeah.
« Reply #5 on: April 04, 2010, 04:38:42 PM »
Points wires were wrong. D'OH! next up is solving my lean mixture
