Author Topic: Starting after sitting for years.  (Read 1667 times)
Offline VitSports6
« on: April 03, 2010, 09:24:15 PM »
 Hi all.
 Just curious if any of you have any suggestions for starting my CB350F after it had been sitting for about 6-8 years?
 I have a new battery I will be putting in tomorrow after it charges, I replaced the spark plugs, added gas.
 Are there any useful links any of you could pass along here?
 Sorry for the newb questions, But I don't want to mess up my new acquisition.
 In the meantime I will be searching here...
 Thanks for any help.
Have fun
 Brian
Re: Starting after sitting for years.
« Reply #1 on: April 03, 2010, 09:26:59 PM »
A carb clean is in your future I'm sure and gas tank also for starters.  Good luck on it.
Offline VitSports6
« Reply #2 on: April 03, 2010, 09:57:16 PM »
 Supposedly the carbs were rebuilt prior to storage, But who knows for sure, I understand that time takes its toll on seals and what not.
  Also I don't have any manuals(still waiting to hear back from my uncle), What it the proper cold start up, ie. Choke setting(lever on the LHS carb?) throttle or not.
 Thanks again.
 Brian
Have fun
 Brian
Offline Grnrngr
« Reply #3 on: April 03, 2010, 10:02:15 PM »
You made sure there's no crap in the tank, right? if they drained the gas from the carbs before storage, they may be OK, but if the tanks rusty and the carbs were full of gas for a year or so, they could be gummy, varnished, or full of rust...And.. Welcome to the club!! lotsa folks pulling the dead ones out of the woodworks nowadays...
'72 CB750-K2 "PopCycle"
'73 CB750-K2 "Barney"
'77 CB750A
'83 Virago 500 (red)
'83 Virago 500 (black)
Offline campbmic
  • Sea-Foam and Flaming 151 is a dam good
« Reply #4 on: April 03, 2010, 10:13:51 PM »
Lets see, aside from what you have already done I would;
-Change oil and filter, at least make sure it has oil!
-Take off the tank, pull the petcock and drain all of the gas and make sure petcock isnt full of filth.
-Take off the four bowls under the carbs. I use a socket with a phillips bit in it to make my life easier. Check to see if theres any rust or debris in the bowls. Then put the tank on fill it up and place a long skinny Tupperware container under all four carbs. Turn the petcock on and collect the gas thats coming out of the carbs. Check the gas for really heavy debris that could have been in the carbs. If theres a ton I would recommend you rebuilding the carbs before starting it up.
Its hard to be wrong when you know nothing!
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #5 on: April 04, 2010, 06:51:37 AM »
Fresh battery and plugs.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline wrenchmuch
« Reply #6 on: April 04, 2010, 07:22:34 AM »
Pull your plugs back out and remove the two outer exhaust side tappet adjustment covers . Turn it over untill you see oil at the tappet adjustment covers . Use short 10 second bursts on the electric starter or kick it . Once you see oil you know your engine is " wet ".
CB750K1
CB750K4
Offline VitSports6
« Reply #7 on: April 04, 2010, 08:29:19 AM »
 Cool, Thanks all.
 I've got the battery installed, I tried it to see if it would crank and it wouldn't... I kick started it a little and the oil light turned off, Yes, I checked for oil a week or so ago  ;D , So it seems to be making oil pressure.
 I will check the fuel tank and shut off valve for crud.
 One thing I have noticed is the motorcycle if really hard to push, I don't know if its the front or rear hub, But soon I will be getting around to it, Now that I think about it, This should be easy to figure out since I have it on the stand.
 I down loaded a repair manual so I will be going over that to see if I can find any issues.
 Thanks again.
 Brian
Have fun
 Brian
« Reply #8 on: April 04, 2010, 08:35:42 AM »
Probably your front caliper,very common problem,almost have to clean them out yearly to keep them working well,not hard to do and rolls a lot better  ;)
Offline VitSports6
« Reply #9 on: April 05, 2010, 06:52:17 AM »
 Welp... I pulled the carbs to have a look inside, They looked pretty good for sitting for so many years, The fuel line from tank to carbs was gummed up with something so I need to replace it. I got it to spit and sputter for a second so all seems to be going in the right direction.
 I'm going to run some seafoam through the tank and crank case then change the fluids, I need to check up on lubing the chassis.
 Thanks for all the thoughts.
 Its been fun tinkering with it this last weekend.
Have fun
 Brian
Offline VitSports6
« Reply #10 on: April 18, 2010, 08:10:16 AM »
 ITS ALIVE!!!
 http://www.flickr.com/photos/77197343@N00/4530816623
 I put on the aftermarket exhaust and tightened down the down pipes, It sounds quite a bit better, I do have a question, I have no idea what part I am missing, Now I could call it a muffler bearing(which is an joke on other vehicle forums) What say you?
 I also tried to polish the fairing that unfortunately had sat out in the sun for the 8 some odd years it was stored.
 I'm kind of mad at myself, I had over written the before pic's with the after pic's, I deleted the before pic's from the camera...
 I know I need to do quite a bit more maintenance, The 1 and 4 cyl don't seem to fire consistently, Which you can hear in the video, I'm not quite sure yet if its timing or a fuel issue, It is certainly a cold blooded old thing, Just like all my old rigs.
« Last Edit: April 18, 2010, 08:12:14 AM by VitSports6 »
Have fun
 Brian
Offline VitSports6
« Reply #11 on: April 20, 2010, 08:09:29 PM »
 I got another package from my uncle!
 I cleaned it up a little, But tell me what you think?!?
 Sorry for the dark pic's I just got finished with it, Its a "Triple-A" sissy bar, It had the rear turn signals attached, I also got a book rack of sorts and a front hoop/tip over bar and some saddle bags that I may need to see IF I can get them to work or not.
 Another thing, The muffler bearings I was asking about were custom made out of stainless steel, I may need to have another set made or search for some other mufflers.
 There isnt much left to do now other than get it running better change the oil, get it licensed and enjoy the summer.
Have fun
 Brian
